MPG on 2002 DRW with auto and 3.55's?
Re: MPG on 2002 DRW with auto and 3.55's?
Originally posted by Intercooler
Anyone know about what can be expected for MPG with and extended DRW that has 3.55's and an auto? This is all highway driving going 70-75 MPH?
[QUOTE]Originally posted by killfast1
I do and that is hand computed cause I dont have the overhead . So if you dont know my truck then dont say anything. Just cause you dont doesnt mean somebody cant. [/QUOTE
if you see my sig i have the same truck and you are a liar or you are not driving over 45.either way you are wrong...we don`t need people to try feed all kinds of bs to us .... i have been around for a long time so i know!!!!!]
I get 20 to 21 with my dually on the highway all the time. If you go over 65 expect less. I don't go over 65. I got 19 for 500 miles with 3000 pounds in the bed last summer.
I also have 4.10 gears
It all in how you drive. If you race ricers you get 15 or less. If you do burnouts you get less besides wear out the tars.
Oh ya Mine is manual calculated. I don't even use a calculator.
My 2002 4X4 3/4 ton auto 3.55's gets 18-21 at 75 mph, depending on wind and all that good stuff. With a slide in camper, and my trucks weighs in at 10,007 pounds, i see about 14 at 70 mph.
[QUOTE]Originally posted by johnh
Dont you call me a liar. My truck does get 24-26 mpg running at 70. if I go over 70 like 71 then the milage goes way down. I generally run with cruise set at 69 so that I do not go over 70. when I hit 75 milage comes back up some. This truck has done this since I got it. You do not know me and have no reason to call me a liar.
Language edited by Moderator
I guess you know this though as you have been around for a while.
MPG on 2002 with 3.55
I have a 2001 with 3.55 and 6-spd 4x4 and with a built in mileage computer so i have checked mileage a bunch of times at fixed speed over (almost) level ground at a constant speed
at 50 mph i get about 25-26 mpg
55-60 mph about 20-22
at 75 ( measured it last summer in North Dakota on interstate) about 17 mph
this is either running almost empty or with a small cap on the back-constant speed with cruise control
i am about to put in a slide in camper in back and hope it doesnt hurt mpg too bad
Re: MPG on 2002 with 3.55
you are the only one with a dually with that kind of mileage...i think your trying to blow smoke
Nope sorry the only smoke i blow is when i shift.
Like I stated earlier it does do a few weird things.
Upto 69mph or as long as it does not go over 2k rpm it gets 24-26mpg. the variance depends on temps.
between 70-74 mph i get maybe 15 mpg
between 75 and 84 it goes back up to almost 20 mpg
then I tried setting cruise at 85 before and I need a tanker truck followiing me to really go anywhere.
Originally posted by phox_mulder
Only way you're going to see 22mpg on a truck with training wheels is to keep it at 60mph with no hills.
I'd plan on more like 19-20 max, considering it's only 2 wheel drive, if you keep it under 70mph.
(actually, on a dually that is 4 wheel drive
If you go 75 the whole way, it'll drop like a rock to 12-13mpg.
phox
)If you go 75 the whole way, it'll drop like a rock to 12-13mpg.
phox
For what it is worth, I can get 20mpg with my "training wheels" but only at 60-65 mph. But I have a 6-speed, not an auto.
