Mounting Airdog 100
Old Aug 8, 2010 | 04:27 PM
bowhunter57's Avatar
From: I live in Bernville Pa but where I want to live is Colorado
Mounting Airdog 100
I've read about 100 posts on here about mounting the FASS or the AIRDOG /100 (THIS IS THE ONE I BOUGHT) but I'm still very confused some say it's so hard to do and others say it was a piece of cake. Ive got a 1998 1/2 short bed. So come on tell me will I have to make up new brackets to mount the pump or will the factory one work. I'm going to mount it where they recomend ,, on the outside of the frame in front of the left rear tire. What do you think of that location.
I'm open for suggestions. Thanks Bob
Old Aug 8, 2010 | 04:57 PM
duster75's Avatar
I used some of there hardware/mounts and installed it on inside of drivers framerail.I just didn't feel safe with it on outside of rail, theives and road debris, out of site out of mind.Would be happy to show you some pict's if you want.The pita for me was installing lines on push barb fittings supplied with pump. They were a pain in theazz to install full on fittings. Other than that it was not too bad, I loosened bolts up on bed took drivers side 1's out and raised bed (drivers side) to help install lines on tank also installed drawstraw and new fuel level sender while I was at it. Nate
Old Aug 8, 2010 | 09:54 PM
Hay thanks duster75, Pic's would be great I plan on doing this as soon as I get out to and back from Colorado this week.
Old Aug 13, 2010 | 10:15 PM
Well I wanted to get my AIRDOG installed on Wednesday but I was taken to the hospital on Monday night, they left me out this morning they had thought a mini stroke but came up with just high blood pressure.
So anyhow I started at 10:00 AM to put on my AirDog 100 well I stoped for the night at 8:30 PM and I'm still not done I have to cut the fuel tank fill hose yet and run the wiring then the AirDog setup is done then to do the new VP44 and the truck should be good as new again. I just hope I can get the rest done tomorrow before dark.
Old Aug 14, 2010 | 01:24 PM
Junk Man's Avatar
Time to buy a juicer & go on a raw food diet. (Jack LaLane is cheap & works well.) There is very little reason to take better care of your engine than heart & brain. High BP is almost always diet caused. Eat well at home & live.
lastcall190
Apr 16, 2011 02:59 PM
clndesl
15
Feb 16, 2009 12:12 PM
Sapps
Dec 16, 2008 11:44 AM
53 willys
38
Nov 6, 2008 11:18 AM
Super Googan
29
Dec 23, 2007 08:24 PM
