Missing 24 valve?
Old Feb 14, 2004 | 11:34 PM
Stamey's Avatar
Out on a limb here, but if an injector goes it won't be intermittent. Don't want to scare you, but VP44 might be a possibility. I'd look for a flakey electronic part, like a crank sensor before anything else.
Chris
Old Feb 15, 2004 | 12:53 AM
travjrath's Avatar
my truck did that all its life ..its in the pcm flash that it is running on ,(mine started the miss/flutter after a reflash for the 98's) you might notice that it won't do it when the ac is on , but it will if the compresser is not running . it has done the flutter/ miss with all 4 of my vp's that i have had , this is not something to worry about in my opinion
Old Feb 15, 2004 | 09:42 PM
tmoore's Avatar
My 98.5 does the same thing as travjrath explained. When its warmed up and the A/C is off it will seem to have a slight miss. I had to replace the VP-44 and put a new lift pump on in the begining of dec. 03 and it does the same as it did with the old one. It seems to be the most noticeable in the summer when the a/c is on when its at operation temp after if been a hwy speeds and you stop and the clutch on the a/c compressor kicks in and out.
Old Feb 17, 2004 | 08:55 AM
HOHN's Avatar
So, did you ever fid your missing 24 Valve?
Old Feb 17, 2004 | 09:50 AM
SBishop's Avatar
I found it in my truck! Says so on the valve cover
2000 Ram CTD
Dec 16, 2006 05:48 PM
1ST GEN.
Feb 9, 2003 04:57 PM
divekrb
Feb 4, 2003 10:57 PM
Got Smoke?
Dec 21, 2002 12:27 PM
