Might need a vp44
Old Jun 23, 2010 | 01:13 AM
EnesG's Avatar
Might need a vp44
I think i might need a new vp44
got the following codes:
P0234
P0251
p0252
P1688
p0121
Truck turns over but never fires up
I have FASS pump only, no filters, have good pressure actually it was a bit high if anything.. 24psi i might have a bad isolator so i'm going to troubleshoot that first before i do anything with VP.
It is a stock 2000 4x4 Auto just have full 4" exhaust , KDP fix, FASS, fuel pressure gauge.
What would you suggest for replacement of VP44 go with a stock rebuild, or something different.. I'm in the cold MN if that makes any difference.
I've seen those +100HP vp44 "Hot Rod VP44" from thoroughbreddiesel
Old Jun 23, 2010 | 10:48 AM
Midnite's Avatar
I'd go for a Special X pump from Blue Chip. www.bluechipdiesel.com
I think you're right to verify that fuel pressure. 24 psi is too high.
Mike
Old Jun 24, 2010 | 02:02 AM
EnesG's Avatar
any other recomendations,
how is http://www.mwfi.com
Old Jun 24, 2010 | 08:39 PM
Junk Man's Avatar
Those 2 come up the most on the forums. I went with MWFI because performance shop owners who I've observed give good advice recommend them. Blue Chip has good diagnosing info on their site. Same source and local shop also say that hot rod pumps don't last as long. You can get as much extra power with chip & injectors.
Old Jul 1, 2010 | 06:06 PM
EnesG's Avatar
I gotta say Chip is great and awesome help so far..
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
