MAP Sensor
Old Oct 29, 2010 | 06:35 PM
weiercd's Avatar
MAP Sensor
Had my truck throw a PO237 after bringing it to the dealer today for a valve adjustment. I am reading that it may be the MAP sensor. Anyone know where it is located? I have a feeling maybe it was unplugged and they forgot to put it back on during the service.
Old Oct 29, 2010 | 08:14 PM
patriot pearl blue's Avatar
http://mopar.mopar1973man.com/cummin...map-sensor.htm
HTH
Old Oct 30, 2010 | 05:25 PM
weiercd's Avatar
Po237
Thanks that article is helpful, I looked for something similar to that under the hood but was lost in the wiring harness for a bit. Came back in to look into it. Going to check the T-connection for the MAP that my chip has, see if it's messed. I have tried my chip unplugged completely and still have the same start problem. Hopefully the map is just dirty and I will be on my way, I will post my results when I figure it out.
Old Oct 31, 2010 | 12:31 PM
weiercd's Avatar
still have problems
Disconnected the chip sensor this morning and reconnected the factory wiring directly to the MAP was a no go, then pulled the MAP and cleaned it well put it back in and the motor won't even crank looks like the batteries are low so going to try to find someone to jump it.
Old Nov 6, 2010 | 07:01 PM
weiercd's Avatar
Dead in the water
Well the jump start attempt didn't do anything, I have 11.86 volts at both batteries, plenty to at least get a tick tick, out of the starter, I am getting nothing. Anyone have any advice? Would a bad MAP sensor cause this? I am dead in the water hear with winter fast approaching.
Old Nov 6, 2010 | 08:35 PM
rebal's Avatar
truck will run with a bad map what year truck are we talking aboat
Old Nov 8, 2010 | 06:49 PM
weiercd's Avatar
It's a 99, I assume if the MAP was starting to fail it would still run, but if it was completely shot would it cause a no start problem like this?
Old Nov 8, 2010 | 08:02 PM
stlhauler's Avatar
Hey, right now I have a bad map sensor. it is unplugged. I have an edge comp box, now if I plug the map in it goes to limp mode, unplug, runs fine. leave the chip connected & undue the sensor. see what happens.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
