Manometer blow by test
Hey guys,
Got the truck back. I think the issue with the tappet cover gasket was just improper installation. I now have a new problem though. I was working on fixing the fuel leaks I have where the fuel lines meet the head (the shop, once again, didn't get it together correctly). Anyway I had to take off the intake horn to get the #1 delivery tube out. When I took of the horn I discovered that one of the holes (cast in the head) that the four studs screw into is broken off and there was just a nut on the end of the stud. I immediately thought what if this nut comes off in the engine?? I called the PO who is a friend and he said the piece had broken off and caused a valve to stick open. He pulled the head removed the piece, then fixed it with jb weld. The shop put the nut on. I have to call them tomorrow and see if they used loctite or jb weld to keep the nut on. Do you guys have any input on how to fix this? My main concern is that the nut doesn't come off in the engine. Do you think jb weld is enough or should I get it spot welded? I'll post pics in my gallery so you can see what I'm talking about(I don't know how to post them here)
I see them.....
So a corner piece of the intake manifold broke and found its way into one of the cylinders? Hope all was OK besides the random debris stuck in the valve.
Then it looks like someone JB welded something back in place and put a spacer plate on the manifold.....right? Do you have the grid heaters still?
I see them.....
I do have the grid heater and will be putting it back on. I am not sure what you mean by a spacer plate, I havent seen many of these to compare mine to.
Not much about that sounds good..... I think I'd rather replace the manifold plate, since thats what you're after. The head isnt what holds the intake horn in place. And the bolts that hold the horn down are 18 lbs.
I think you may be thinking of a different piece. I just looked on the cummins website and the part that is broken is part of the head casting. The bolts for the intake horn do go through the plate you are taking about, but they thread into the head casting. Unless I'm really missing something....
I see what you're saying. Yes, you're correct that the bolt reaches past the intake manifold plate and threads into the head. I'm not sure what else you could do then. You certainly dont want any loosening debris sucking into the cylinders and you most certainly dont want that nut to fall loose and drop into a cylinder either. To bad your friend didn't have it welded up when he had the head off.
I apologize leathermaneod but I dont think I can answer that without seeing it in person. And for tacking it, well that would be up to the welder and whether or not they thought they could do any good in there. It may last forever or maybe not. I think what got me thinking is when you said the stuff is flaking apart.
Thanks for all the help!
