Made in Mexico?
Old Apr 3, 2008 | 04:59 PM
Saileron's Avatar
Made in Mexico?
First post here, so please forgive my ignorance.
Looking to buy a '99 3500 two wheel drive, five speed, dually - owner says the truck was built in Mexico. Would this mean it would automatically have the good Mexican block instead of the dreaded #53 block from Brazil ? Original, older owner babies the truck and says never had any trouble with lift pump, fifth gear, killer dowel pin or other known 24valve problems - so all original.
Truck is straight, and runs out super good with no apparent problems. 163,000 mi.
Old Apr 3, 2008 | 07:41 PM
afoulk's Avatar
Its possible, but I would still check for the 53 above the oilpan on the left front corner of the engine block, in the area under the powersteering pump/vacuum pump assembley. It'll be just a big "53" cast into the block if it is. If its a real long number, then it is more than likely the mexican block.
Old Apr 3, 2008 | 07:52 PM
Taxidermyman's Avatar
So let me get this straight, all the ones built in mexico DONT have the 53 block? Mine says it was built in may e ho.
Old Apr 3, 2008 | 09:13 PM
PChouinard's Avatar
Mi trukee hecho en mexico con numero cinquenta y tres Check the block to be sure. Luckily mine hasn't cracked so far with 170,000 on the ticker..
Rockram
Feb 21, 2007 10:13 PM
Peterbilt
28
Aug 26, 2006 06:49 PM
Ian
Apr 23, 2005 06:25 PM
Michigan Steve
33
Dec 4, 2003 09:59 AM
AKDSLDOG
Nov 7, 2003 07:55 PM
