LP replacement
Old Jul 1, 2007 | 12:58 AM
1-TON's Avatar
LP replacement
Well I got my fuel pressure gauge installed today. I was reading 8psi at idle, cruise at 55,60,70 it was 5psi, and WOT dropped to 0. Will getting the big line relocation help with the fuel pressure? Or do I need to do the and get another LP. Or should I just add a pusher set up?
Old Jul 1, 2007 | 08:04 AM
tractorguyacb's Avatar
LP Problems
I got a fuel pressure gauge 1 week ago and when i put it on I had the same pressures as you. I decided to go with the genuine cummins one. You cant buy it from dodge so i decided to go to this cummins dealer inn north jersey. They had the LP is stock and it was 150.00. After the LP replacement I have 14 psi at start and it will not go below 10 WOT. Now my truck actually will go over 2500 RPM.
Old Jul 1, 2007 | 12:24 PM
1-TON's Avatar
Thanks. Do you happeto have the part number, that way I dont have to hassle with them when I go to get it?
Old Jul 1, 2007 | 01:29 PM
nickg's Avatar
Check this out
http://xj.cdevco.net/auto/fuelsystem/
kingofdodge7131
Mar 22, 2003 09:39 AM
sennbj
Mar 16, 2003 11:11 AM
ridofpwrstroke
Nov 6, 2002 12:20 PM
blackboat
Oct 27, 2002 05:52 PM
