Low Map Sensor voltage
Old Apr 21, 2006 | 11:43 AM
Gene007's Avatar
I just ran the codes on my truck and its showing a low map sensor voltage. This is a brand new sensor. I checked the voltage going to the sensor and it is showing right at 5 volts which is what is normal. Is there any way to check the map sensor itself? I have checked the old one which I'm not sure was bad to start with and I can't get an ohm reading at all between any of the connector pins or between the pins and the body of the sensor. Should there be an ohm reading through the unit?
Regards,
Gene
Old Apr 25, 2006 | 06:50 PM
bigthumper's Avatar
i've got the same problem.... and the new map sensor has a new number and it is smaller... i've been through two of them
Bad-Duvall
Oct 9, 2008 12:52 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
Meierznutz
Jan 24, 2005 07:04 AM
Zino
Jul 22, 2004 11:12 AM
