Lots of smoke
Old Oct 4, 2008 | 10:11 PM
Thundercraft's Avatar
Lots of smoke
I know that some of you guys want that, but for the most part, I'm happy without it....
I first noticed it this summer pulling the 5th wheel - about 7800#
I was pulling onto the highway from a side road. Wound it up to around 2000 in 1st gear. As I was changing gears I looked in the mirror to see how the trailer was coming around and there was a huge cloud of black wrapping over my box.
After that I started keeping a closer eye on my exhaust. I noticed that under about 1800-2000 rpm the smoke was quite heavy & black. Once the turbo started waking up, the exhaust cleaned right up.
It took several tanks running empty before the truck started to "clean up" and the smoke was a big issue (to me).
I also noticed about the same time that the truck had quite a puff of black on firing up (cold or hot). This too diminished quite a bit over the several tanks.
Then today again I hauled the trailer about 80 miles. Up some good grades (longest was about 3 miles at 7%) from sea level up to about 4500'.
I noticed about the end of the trip again that the smoke levels seemed to be back.
I can't give you EGT temps or pressure, etc. no real gauges.
I can say that the engine earned it's keep (& so did the turbo).
The truck has averaged just over 17mpg this year (total mileage / total fuel purchased).
I don't know if there any mods. None that I know of. However, I wonder if PO did put bigger injectors in.
Only about 10K on the rebuild. (cracked block).
Thanks for bearing with the long post.
Old Oct 4, 2008 | 10:38 PM
hawkdiesel1's Avatar
I got this, i'll post it later. Its nothing to worry about though
Old Oct 5, 2008 | 02:25 PM
scottsjeeprolet's Avatar
Air filter dirty?
Towing like you are without gauges is taking a big risk.
Try cleaning the MAP & IAT and see if that helps.
Start saving for gauges.
Old Oct 5, 2008 | 07:15 PM
Originally Posted by scottsjeeprolet
Air filter dirty?
I know I need guages.... but since (I believe) the truck is stock, I wasn't too worried that I was stressing anything too much.
Air filter is only about 2 months old - AMSOIL EA drop in.
I did pull the sensors about 3 or 4 months ago and cleaned them. Wouldn't hurt to check them again.
Good tips. Thanks.
Old Oct 5, 2008 | 07:48 PM
At the very least put a test gauge in and check your fuel pressure. Even on stock trucks they fail. Quite often too.
Old Oct 6, 2008 | 07:50 PM
That is something I should do - regardless. Good reminder.
A thought occurred to me today.... a few times in the last month or two I've noticed the tach flicker a bit while cruising along at a steady speed. Just 1 or 2 hundred rpm and just for a brief moment before settling down again...
I wonder if my CPS should be replaced??
06RED-BARON
ABDTR #5
66
Dec 20, 2008 04:59 PM
TexMexCowboy
Sep 25, 2007 10:19 PM
rbrettctd
May 31, 2007 12:34 PM
PurNLoud
25
Mar 23, 2006 11:01 PM
muddin4fun
Jul 22, 2004 09:11 AM
