Loss of power w/high coolant temp
Old Aug 29, 2011 | 06:05 PM
Gannetpeak1's Avatar
Gents,
Last weekend I towed my trailer from Phoenix to Flagstaff on I-17. My truck seemed to loose most of it's power, so much so that I had to manually downshift my trans to 2nd then to 1st and I could only make about 15-20 mph. I had previously noticed my coolant temp was maybe 220-230 and I slowed down to around 45 mph in 3rd. Suddenly, power was restored and it seemed like it was related to the coolant temperature. The loss of power was so pronounced it was almost like I had a dead accelerator pedal. No codes set and no check engine light. Any ideas on what this may have been? Thanks for any ideas.
Old Aug 31, 2011 | 11:37 AM
lrb1182's Avatar
I pulled a load of hay this weekend and experienced the same problem. When I figure it out I'll post. Maybe someone will give some ideas.
Old Sep 1, 2011 | 08:33 AM
bcbigfoot's Avatar
There is a engine defuel at approx 226 degrees. It is to reduce the chance of engine damage at high temp.. Ecm is likely thinking a fan belt or hose blew. I believe it should have thrown a code 217 if I remember correctly.
RHC
Aug 12, 2019 03:32 PM
schamran
Oct 29, 2013 07:06 PM
tntk9
Nov 20, 2012 07:09 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
