Location of TPS/Apps?
Old Jun 29, 2005 | 08:52 AM
Hoss15's Avatar
Question Location of TPS/Apps?
Where is this TPS/APPS located? i Have searched many websites, seen many pictures of this monster but have have not seen (exactly) where it is located. Is is visible or do i need to remove the throttle assembly? or am i looking in the wrong place? I have the "noise problem" or "gear hunting" issue. Some say it can be cleaned others say no. I have heard cost of replacement anywhere from $40.00 (us) up to $900.00 (us). I am aware of the "filter" that can be bought to help this problem. I also have learned about cleaning the grounds and the batteries and checking all the electrical connections and the wire being run with the alternator wires and the voltage spikes.
But my question is: Where is this located? is it visible to the eye or do i need to remove some parts. I am not a mechanic but with a little info and lots of ambition i can fix some problems.
Thanks in advance,
Hoss15
Old Jun 29, 2005 | 09:02 AM
crobtex's Avatar
If you'll look in my gallery at the pic, it is located under the black cover, (below dip-stick). I got mine from Cummins South Plains for $336.
https://www.dieseltruckresource.com/...cat/500/page/3
Old Jun 29, 2005 | 10:07 AM
Hoss15's Avatar
Wink
OK i took that cover off a couple of days ago. Do i need to remove the throttle assembly to be able to gain acces to this darn thing.
Thanks,
Hoss15
Old Jun 29, 2005 | 12:55 PM
Hoss15's Avatar
Thanks for all your help I ordered the noise filter. i will let you know if it works when i get it.
Hoss15
Old Jun 29, 2005 | 04:03 PM
crobtex's Avatar
The APPS is an assembly that is calibrated at the factory.
If a noise filter would have fixed mine, I'm going to be PO'd.
Old Jul 8, 2005 | 07:44 AM
Hoss15's Avatar
Smile
Just installed the noise filter last night 7-7-05. I will monitor and keep in touch. This last week the problem has been almost non existant (once or twice) since i wiggled and checked a few connections and grounds. I didn't find anything loose or bad but maybe just moving them temporarily helped the problem.
Hoss15
Old Jul 18, 2005 | 09:19 AM
Hoss15's Avatar
Noise Filter
I installed the noise filter back on 7-7-05. It has been good since except when the A/C MAX is on. Regular A/C it is ok. but when the A/C Max is turned on it acts up. Next thing is to seperate the wires from the large cluster. any other ideas?
Hoss15
Old Jul 18, 2005 | 10:51 AM
neveragain's Avatar
noise filter
What part # does cryslurrr or NAPA or who call the noise filter.
Old Jul 18, 2005 | 12:45 PM
Hoss15's Avatar
I got mine from diesel transmission technology (DTT). 1-866-504-4002 I believe they are located in Abbotsford, B.C. Canada. Part #KW5535
Old Jul 18, 2005 | 04:26 PM
Mike D's Avatar
Here is something that I noticed, might mean nothing? I cleaned my battery terminals a couple of months back and reset my apps. Shortly there after I started getting the T/C unlocking problem. I went out and started checking everything and tried to wiggel the neg. side terminals and they moved! So, I got the wrench to tighten 'em up. They wouldn't tighten anymore, noticed they were bottomed out.
I gave the bolt on the terminal some slack and used a rubber hammer to tap the terminal further down on the post. As I did, I noticed they started to spead apart just a hair. I put the wrench to them again and could not wiggle them loose. T/C unlocking gone.! I never took the terminal off or reset the apps. Must be a bad ground issue.
whosdunit
May 17, 2014 08:54 AM
supr
18
May 21, 2007 09:29 AM
59FORD
Apr 7, 2006 12:28 AM
napa 600
Jan 20, 2006 02:57 PM
Cruzer75
Jan 2, 2004 04:34 PM
