Limp mode when cold
Old Oct 31, 2010 | 10:01 AM
snowjoker's Avatar
Limp mode when cold
My 99 has this issue going into limp mode when its cold out.. maybe below 50 degrees. I changed out the Governor pressure solonoid, and the transducer too.. Any suggestions? maybe a different brand fluid ? The heat exhanger has been bypassed if that makes a difference, but its not really cold out enough to say so if you ask me ? ? It is fine once the tranny warms up, but this is a plow truck and i need it reliable from the time i start it up and head out..
Old Oct 31, 2010 | 11:11 AM
rebal's Avatar
have you tried putting it in N to let fluid flow for a few seconds? if that's it you have a seal leak also how is the fluid level in N warm.?
Old Oct 31, 2010 | 05:14 PM
snowjoker's Avatar
The fluid level is fine, but ive not put the truck in N to circulate the oil..
Old Oct 31, 2010 | 07:14 PM
nickg's Avatar
is the tranny going into limp mode or is the truck just not responding to the throttle, also what codes does it have?
Old Nov 1, 2010 | 09:06 AM
snowjoker's Avatar
It only does it when the temps are like below 50 degrees.. once it warms up it is fine and has no issues at all !
Old Nov 1, 2010 | 09:57 PM
nickg's Avatar
so what codes do you have, and is it a tranny shifting issue (starting in 2nd gear) or a dead pedal issue????
Old Nov 2, 2010 | 03:42 AM
snowjoker's Avatar
no codes..... it just starts out in 3rd gear...
Old Nov 2, 2010 | 07:38 AM
nickg's Avatar
there are voltage regulators to correct this, if your gov pressure is too high, typically this happens if you have an aftermarket VB, or faulty gov sensor. I see you have replaced yours, so I'm at a loss unless your "new " one is defective or the wiring harness inside the tranny is wore thru or has a break somewhere.
Most tranny shops offer free scans and can diagnoise better than we can, they likely can confirm if the sensor is actually working or not.
frequent 3rd/2nd gear starts will tear up the tranny (this I'm sure you already know this)
tj97dodge
Jan 14, 2006 01:55 PM
swimmy
Dec 3, 2005 09:52 PM
OldSmokey
Mar 26, 2005 06:53 PM
arctic426
Feb 28, 2004 06:22 AM
danlit
14
Jan 20, 2003 06:55 AM
