Lift Pump Mess-up
My oem lift pump was running low pressures (6-7) at highway speed. Engine ran perfect but started hard, sometimes impossile to start when hot. Got tired of having to leave engine running continuously on long trips, so I installed a Holley black lift pump back by the tank, running through the original pump. The pump is supposed to be factory preset for 15 psi, but my gauge was showing 25-30#. I drove it 150 mi. today and it started harder than ever (but performed perfectly as usual when running). After I got home, it sat an hour and took a long time to start. I drove 5 miles. An hour later, it wouldn't start.
Questions:
Why is my pressure so high?
Did the high pressure cream my VP44?
What kind of regulator to use-the one for the Holley Black is only adjustable 41/2 to 9#?
Thanks, Bud
Questions:
Thanks, Bud
2) Not likely. VPs don't like higher pressure when trying to start--once the engine is running, high FP isn't a problem.
3) Use a BYPASS regulator with a return line-- I'm partial to aeromotive regulators.
