lift pump fix...cheap and easy
Old Dec 2, 2006 | 10:50 AM
dieselbeef's Avatar
Muted User
got a campaign pump from cummins to replace the bad one..85$
got a holley red pump to make pusher pump...110$
relay to jump off the orig lift pump power wire....30$
3/8' hose and clamps misc crap...40$
15-20 psi steady fuel press
PRICELESS!!!!!!!!!!!!!!!
not a difficult fix...rcommended by.......ME!!!!
Old Dec 3, 2006 | 11:52 PM
widetrak60's Avatar
How about this insted
got a campaign pump 4090046-15 from cummins to replace the bad one
got a pump relocate kit from genos
going to put pump back by tank
any thoughts?
Old Dec 4, 2006 | 04:00 PM
qwest's Avatar
Did the same, with the bigger banjo, runs at 13-14 psi
drops no lower than 11, Banjo made about 1-2 psi on
low limit at full power
Old Dec 4, 2006 | 09:14 PM
widetrak60's Avatar
where do i get bigger banjo? and what size is it?
Old Dec 4, 2006 | 09:41 PM
Devin_01's Avatar
just wondering if you could just put two of those cummins pumps on. One in the stock location and one by the tank?? Is this a good idea or not????
Old Dec 4, 2006 | 10:14 PM
b4wheeler's Avatar
You can do it. Vulcan says you could get upwards of 30 psi. They recommend a relay that is activated by oil pressure so you start the truck on one pump and run off both.
High initial fuel pressure can create a hard start problem.
I have a friend that runs the stock LP and a Holley Blue pump with no problems.
I may eventually add a second campaign pump in the stock location for more psi if I need it.
Old Dec 4, 2006 | 11:22 PM
piperca's Avatar
Honestly, I wouldn't waste my time with a stock pump. You can get a Walbro for $100 and a few dollars extra would provide you with the parts for a bypass. The 1/2" or 3/8" lines are a nice touch, but, if you were on a budget, you'd be able to get by without them. Definitely an option worth looking into!
Old Dec 5, 2006 | 05:22 AM
Devin_01's Avatar
So will fuel run thought these campiagn pumps without running???
Old Dec 5, 2006 | 05:26 AM
P.J's Avatar
P.J
any thoughts?
Done it, worked flawlessly.
Old Dec 5, 2006 | 06:11 AM
OHFarmboy's Avatar
I ended up just bolting on a Holley Blue on my frame rail, after a new lift pump and a new injection pump (under warranty) the piece of mind is priceless! Especially now that the truck went out of warranty 4 days ago!
Old Dec 5, 2006 | 10:31 AM
Doug_TX's Avatar
Is there an online source for the 'campaign pump'? Or a place where I can get one?
Old Dec 5, 2006 | 10:41 AM
P.J's Avatar
P.J
Local Cummins dealer is the easiest (if there is one near you).
I could have sworn Geno's Garage was selling them a while back, I remember thinking how odd that was.
Other than that I have never heard of them being sold on-line.
Old Dec 5, 2006 | 10:46 AM
P.J's Avatar
P.J
Part Number 4090046
Old Dec 5, 2006 | 11:41 AM
kinser5mfan's Avatar
what is the difference between a holley blue and red
Old Dec 5, 2006 | 12:35 PM
johnh's Avatar
hoesli diesel, but you have to have an engine number from a bus or ambulance
