lift pump concern
Checked out the walbro web site. Inline pumps run around 100 bucks but you still need to get mounting hardware, fittings, and lines. Not to mention the electrical connections like a relay, wire and whatever. The raptor kit looks pretty darn good to me and I have not heard anything bad about them even on other threads. So who has the best price?
I think the Vulcan big line kit is aa good solution. The Airtex pump seems to be a better OEM type pump than the Carter. Seems the expensive pumps can fail too. When they do, no spare, unless you have lots of money. I think the Airtex may be the best non expensive solution for stock & near stock applications. The pumps can be changed with the Vulcan setup in 10-15 mins, worst case.
Ok my question is.....if I buy a FASS DDRP, can I mount it on the frame rail and leave the old original lift pump in the tank? I didn't know if it would pump fuel through it or not. Id probably rather put a drawstraw in the tank and let it suck fuel freely rather than try and suck fuel through the pump. Am I correct on this?
Send me a PM and we can talk particulars.
Dave
What is the difference between the vulcan big line kit and the line kit that comes with the raptor? Also, what size line is in the draw straw kit as compared to stock? That requires drilling a hole in the tank right?
We use bio/ veg oil Diesel compatible fuel lines. The Draw Straw is roughly 1/2"
The stock pickup has a 3/8" flexible tubing. In between these sections, you have internal plastic barbed fittings. (depending on year) Some of the modules are more restrictive primarily due to these restrictions. This is what the Draw Straw was born from.
However, some modules flow more freely in stock form. The metal module fittings do flow better than the plastic. This is all due to wall thickness. The plastic much be much thicker to do the same job as the metal and this results in an ID in the .24" range. Just slightly under 1/4" ID.
Dave
Dave
Yes. If you can get your head up there and he top of the module is clean enough, you can see it. Typically, the metal lines have a radius to them. The plastic unit is at a 90* angle.
Most 2000 and up are plastic.
Dave
Dave
I have 91,000 miles on my 99 3500 DRW. At 82,000 I replaced the original lift pump only because I wanted to insure that I would not have problems on my summer trip. The old pump worked fine so I kept it as a spare. At 90,000 I began to see my fuel pressure idiot light flicker and come on. Since I also installed a pressure gauge on the filter canister I was able to verify that the new pump was actually failing. The point of my story is that the stock lift pumps fail; even a new lift pump can fail quickly. So install a fuel pressure gauge or at least an idiot light and carry a spare lift pump. I am still using the old pump but I’m waiting for my Airdog 100 filter/pump system to arrive any day now.
Tony
Tony
Tony
Tony
Of course the DSI is intended for trucks that do not have an intank pump or retrofit.
Dave
My gauge never falls below the FP I want, but it's just a wimpy original stock LP that's 7 years old.
I'm also only running about 420hp worth of fueling.
