Left Hub Bearing Replacement 99 4x4
Old Aug 8, 2010 | 11:48 PM
DieselPoor's Avatar
Starting to loose some lube left front. Suspect hub bearing with 102K. I want to confirm I can replace the left and not do the right yet. If y'all could confirm it is OK to do the left side only I will start checking prices on the left hub bearing.
Old Aug 9, 2010 | 12:56 AM
DIESELWRKS's Avatar
I did my driver side last year, my pass side still is tight but I bought another for the shelf when time comes.
Old Aug 9, 2010 | 06:54 AM
pwregan's Avatar
hub repair
dieselpoor,
at the milage you are at with your truck and the depth you are going to have to go to get the hub out-do your ball joints while you have it torn down, if they are not shot,they are right about to be and you will have everything apart anyways- be sure to read MR GADGETS write up on ball joint repair-it will show you how to get the hub off and remove the ball joints-xrf ball joints can be bought on ebay from thetireclub- you will regret not doing the ball joints while you are in there- good luck
Old Aug 9, 2010 | 09:58 PM
DieselPoor's Avatar
Thumbs up Thanks
Good advice gentlemen and much appreciated!!
Old Aug 10, 2010 | 11:10 AM
BigGreen's Avatar
Yes pwregan I agree very good advice and maybe the shaft u-joints. But make sure you anti seize the hub before you put in.
Old Aug 10, 2010 | 05:02 PM
DIESELWRKS's Avatar
second that after doing one you will never forget a good anti-seize.
malittle
0
Sep 12, 2012 03:26 PM
Rafter B
Jan 11, 2009 08:40 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
9512vCTD
Dec 4, 2006 10:09 PM
CTD99
Sep 16, 2003 06:41 PM
