Leaking windshield wipper fluid bottle.
Old Dec 5, 2003 | 07:15 PM
KATOOM's Avatar
I just noticed that my windshield water bottle is split and leaking, unfortunately, after I just poured a whole bottle of fluid into it. I called and they cost $53. Has anyone fixed their leaking bottle or should I go buy one. I wasnt sure if they are prone to leaking. The leak is right on the seam were the two sides are joined together. Plus it almost looks as if I have to remove the top radiator hose to get to the bottle.
Old Dec 5, 2003 | 07:39 PM
Tom's Avatar
Tom
Re:Leaking windshield wipper fluid bottle.
Katoom,
I don't know if a repair would hold at the seam there, because of the vibration of our trucks. It might be worth a try though. However, you might be able to pick one at a salvage yard for less money than a new one.
Tom
Old Dec 5, 2003 | 07:42 PM
crobtex's Avatar
I used a thick RTV on mine. After a couple of appications, it quit leaking.
CR
Old Dec 5, 2003 | 07:58 PM
Dr. Evil's Avatar
$53 is quite a bit.....you could check with a truck wrecker....or if looks arent important, get some of the Steel Impregnated epoxy putty (Permatex makes it). I fixed my air box with it after the quick oil change guys busted it. You can file, sand, and shape it after the repair. Use RTV on the inside and this stuff on the outside of the rtv and Im sure it will hold.
Old Dec 6, 2003 | 06:58 AM
sherod's Avatar
Two years ago I fixed my neighbors' with two part epoxy. It was leaking at the seam also. No leaks since then.
Ed
Old Dec 6, 2003 | 03:52 PM
KATOOM's Avatar
Thanks for the tips. I'll try something. I just didnt want to have to take it off. Like I said earlier, it looks like the top radiator hose has to come off. I would assume the entire seam is prone to leaking though.
Old Dec 7, 2003 | 08:20 PM
magnum's Avatar
Katoom--Your washer bottle should be made up of polyethylene. As an auto body instructor, students plastic weld these items all the time. If you don't have a plastic welder, a soldering gun will work, just "fuse" the plastic back together. Magnum
pwregan
Apr 27, 2013 04:47 PM
53 willys
16
Apr 30, 2007 09:30 AM
Larry R
Apr 24, 2006 08:42 AM
Nate-03 D
Jan 4, 2006 08:05 AM
KATOOM
Mar 14, 2004 12:18 AM
