leaking transmission coolant lines
Old Mar 4, 2010 | 12:31 PM
e6ranch's Avatar
Unhappy leaking transmission coolant lines
Hi, My husband and I are new to this forum but have a problem that has plaquing us for months; two rubber transmiision lines with quick connectors at each end, from the hard line to the radiator end. We tried ordering new lines with quick connectors only to get them installed and still have them leak. So my husband tried to patch them up with heated hose, but that is not working. He is thinking of using hard line (like copper line?) with compression fittings. Does anyone out there have experience with this problem? We could sure use some tips on how to fix this seeming easy repair.
Thank You,
Michael and Sharon
2000 Dodge Ram cummins Diesel 2500 Quad Cab 4x4.
Old Mar 4, 2010 | 12:44 PM
johnh's Avatar
Thank You,
Michael and Sharon
you can replace the rubber lines with transmission cooler hose from auto zone or napa , but use the clamps designed for fuel injection,and double up on them........no leaks
Old Mar 4, 2010 | 02:44 PM
e6ranch's Avatar
Thanks John, we will give it a try. Right now though he is a little concerned that we let the trans run dy and ruined it, so I may be back with worse problems, thanks for your response though.
Old Mar 4, 2010 | 06:14 PM
2500superram's Avatar
right before those metal line's turn into rubber they cross over the frame on the driver's side of the block.make sure the line hasn't wore through rubbing on the frame.leak's like this can travel down the line and appear like it is comming from another area
Old Mar 5, 2010 | 01:06 PM
SIXSLUG's Avatar
There was a recall back on the 94's that concerned changing the plastic fittings at the trans to metal ones for the cooler lines. This should not be a problem on your year unless the trans hasn't been replaced or changed, but check there too.
Old Mar 5, 2010 | 01:13 PM
Dangousity's Avatar
I have (twice) blow the pressure line on the tranmission cooler (knocks on wood) and my Xmsn is still holding. I went and bought actual HYD line, used a tubing cutter and removed the fitting, ran the line through back around. installed new flex bumpers so the alum lines wont rub on the axle tubes or the oil pan. Took off the old holders. Works great now.
Old Mar 14, 2010 | 10:57 PM
vrj's Avatar
vrj
Did you remove the bumper to get the transmission cooler lines off or did you remove the radiator?
Old Mar 23, 2010 | 09:58 PM
calltrex's Avatar
i just removed mine tonight. move a/c out of the way and just remove the inter cooler
Old Mar 24, 2010 | 10:12 PM
vrj's Avatar
vrj
I was able to disconnect the transmission cooler lines at the cooler without dropping the bumper or pulling the radiator/inter-cooler.
I just moved the cooler inlet & outlet a little to unscrew the clamps. I had just enough play.
Took the lines to my neighboorhood hose man and he fixed the lines by removing the quick-disconnect and installing an AN fitting with new high pressure hose.
It cost me approx. $55 total to fix both lines !!! A huge difference in reference to the dealer.
Thanks for the comment.
wilderness
Jan 15, 2014 12:42 PM
wilderness
Jan 14, 2014 10:59 AM
91rangerturbo
May 8, 2008 08:05 AM
91rangerturbo
Mar 6, 2008 09:40 PM
