leaking dana 80
Old Apr 10, 2009 | 06:34 AM
D.S.'s Avatar
leaking dana 80
I changed fluid in my front and rear diffs a few weeks ago. This past weekend I made a long trip w/ a couple of horses (probably really getting the fluid hot for the first time since i changed it) and a seal where the driveshaft inserts into the rear diff, sprung a leak. I of course checked the fluid level and it was still about 1/2" below the fill hole. How bad can a leak like this get and how hard is it to fix? Is it something I can ignore as long as fluid doesnt start drip dropping out and the fluid levels seem good or do I need to change it immediately?
Thanks for the help, Drew
Old Apr 10, 2009 | 06:42 AM
Common's Avatar
Jack the rear end up = placing the jack underneath the diff.
Grab the driveshaft and try to move it up and down - see if there is play by the yoke - it could be a pinion bearing.
Old Apr 10, 2009 | 03:49 PM
2500Ram's Avatar
I'm missing something here. If you jack up the rear of the truck via the pumpkin your not doing anything to reduce pressure on the drive shaft correct??? maybe if you jack up the truck via the frame, or am I way off.
Old Apr 10, 2009 | 05:48 PM
patdaly's Avatar
Way off, you are trying to reduce the pressure on the tires, there should be no pressure on the driveshaft, it will slide in and out depending on the driveshaft angle.
Old Apr 10, 2009 | 10:41 PM
D.S.'s Avatar
No worries (knock on wood) a very knowledgeable mechanic friend of mine checked it out this evening and siad it was just the seal--Im going to do what little I can to help him change it for me this Sunday.
Thanks, Drew
Old Apr 10, 2009 | 10:48 PM
bob4x4's Avatar
Be sure to have a puller on hand and do not be surpried if the yoke has a groove worn in it.Your option will be to find a wear sleeve or buy a new yoke at that point.IRRC you will need a 1 5/16 very thinwall socket.
Old Apr 11, 2009 | 05:45 AM
D.S.'s Avatar
Thanks for the heads-up info.
Drew
tankeryanker
14
Jan 19, 2005 04:18 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
