ECM and PCM
Old 10-05-2018, 08:24 AM
Camaro68's Avatar
ECM and PCM
The ECM and the PCM are not communicating. The truck has went into limp mode, it has a bully dog on it that I just disconnected . I’m thinking add a few ground wires and see if this solves the problem. The truck had been sitting a few years, it was in limp mode. It was throwing a code for lift pump, I installed a new air dog on it, and it wouldn’t come out of limp mode. Sidenote, I drained and replaced fuel.Comments welcome
Old 10-16-2018, 03:59 PM
AlpineRAM's Avatar
Better late than never-
The air dog will cause a code for the lift pump- because the ECM "feels" a relays instead of an electric motor.
This has nothing to do with the problem of no communication- try the simple things first- check the wiring for corrosion and broken wires.
(A lot of the problems with these trucks can be solved by accepting that 20+ year old wires are not new..)
Maybe you can find a Cummins dealer or a Dodge dealer who still has the equipment to test either your PCM(Dodge) or your ECM(Cummins) for you.
Camaro68 (10-16-2018)
bullboy85
02-11-2011 08:49 AM
mini14
01-13-2008 09:13 AM
Big Perm
12-18-2007 08:44 PM
newtododge
03-25-2006 08:15 AM
Quick Reply: ECM and PCM
