Just flushed the coolant...
Old Dec 19, 2004 | 02:45 AM
BigBlue's Avatar
Hemi cat, I got some conditioner to kill all the stuff in the water.
Supermod56, I wound up using a cummins thermostat. Truck never runs over 190* now no matter what I do to it.
Old Dec 19, 2004 | 06:43 AM
Supermod56's Avatar
Excellent!!!! You get what you pay for!!
Tom
Old Dec 19, 2004 | 08:31 AM
jethroish's Avatar
This being my first diesel and, I guess since my needle is fluctuating some, needing to do a flush on mine,
Is it ok to use any (name brand) coolant? Of couse Cummins wants you to use theirs, but they also told me that whatever I use, to be sure that it it Low Silicate.
Does the conditioner accomplish that?
And since it was mentioned here, would some one please email me how and where they moved the blow by bottle? As it is right now, I just spray the fan and front of the engine, every oil change, with some Simple Green. Cleans it off pretty good.
I love useful foums!
Thanks
Old Dec 19, 2004 | 10:01 AM
MnTom's Avatar
One thing to keep in mind is the green stuff is very toxic. I have been told that one teaspoon full is enough to kill a cat. did witness a dog die from anti-freeze poisoning once.............it ain't pretty. Having a well for my water I try to be carefull about what gets spilled.
Tom
Old Dec 19, 2004 | 02:21 PM
BigBlue's Avatar
Supermod, for $42, it better stay at 190*.
jethroish, how many miles do you have on the coolant? You might just want to change the thermostat out. Even after 74K miles on the original coolant on mine, it was still neon green and there was absolutely no sludge in it. Only reason I did all of mine was because I got bored and had the money.
Old Dec 19, 2004 | 04:46 PM
jethroish's Avatar
"jethroish, how many miles do you have on the coolant? You might just want to change the thermostat out. Even after 74K miles on the original coolant on mine, it was still neon green and there was absolutely no sludge in it."
I have 64k on the original fluid. It still looks bright green, but I noticed under the rad. cap, on the spring, there was some gunk looking like snot. Other than that, it looks real good.
"Only reason I did all of mine was because I got bored and had the money."
If you have any more that you don't need...
Old Dec 19, 2004 | 05:14 PM
BigBlue's Avatar
I wish I did. But I've got to buy a lukes link now to fix my track bar and then I got to get it aligned.
Old Dec 19, 2004 | 08:42 PM
JARHEAD's Avatar
Just had to add my two cents. Another great antifreeze is the John Deere premix. It is already mixed and has the initial charge for proper sca levels. I believe it is supposed to be good for a year then you need to check the sca levels. It is a little bit more pricey but it is all in one package.
dodge35000
44
Nov 27, 2011 09:48 AM
elirandolph
Sep 29, 2009 06:56 AM
buddy26
19
Feb 16, 2008 01:27 PM
dodgediesel4x4
17
Aug 31, 2005 07:48 PM
rico334
Dec 10, 2004 02:35 AM
