Intermintent starting problems
Old Jan 8, 2013 | 09:08 PM
ihbrad's Avatar
99, Fass pump and boost fooler.
I got stuck in town because the SOB would not start tonight. This has been an on and off issue but has gotten worse in the colder weather.
Here is whats going on.
I could turn the key and hear the short lift pump cycle. Bump the starter and the pump does not run. After an hour of messing around and having my father in law make a half hour trip with his wrecker to rescue me it started.
While trying to get it to start I ran a jump to the lift pump and it ran just fine but the engine would not start like that. At least I know the wires are good going back.
Do I have a bad ECM ? It will be plugged into a tester tomorrow. Any other suggetions? I see conflicting info on here. I see some refer to the PCM as turning on the lift pump and some refer to the ECM. Which is correct?
Thank-you
Old Jan 11, 2013 | 06:47 AM
iwhitne's Avatar
mine does that sometimes... in cold weather it will sometimes run the lift pump after bumping the starter and sometimes it won't... I think it has to do with the grid heater cycle... I can usually bump it a few times and it usually kicks on.... sounds like you have a fueling issue as well
Old Jan 15, 2013 | 01:34 PM
bigfish95971's Avatar
Most likely batteries are about done. Have them LOAD CHECKED. YOU WILL FIND YOU ARE DUE.
Old Jan 16, 2013 | 09:57 PM
ihbrad's Avatar
[QUOTE=bigfish95971;3160314]Most likely batteries are about done. Have them LOAD CHECKED. YOU WILL FIND YOU ARE DUE.[/
The truck is spinning over very good , its just not starting. The lift pump is not getting the signal to run sometimes.
Thats still battery related??
ihbrad
Jan 16, 2013 12:32 PM
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
mastersa
Jan 30, 2008 09:50 PM
abc4yew
Mar 15, 2007 11:55 PM
