Installing new BHAF
Old Oct 31, 2002 | 05:20 PM
cr1998's Avatar
Installing new BHAF
New BHAF was delivered this afternoon and plan to install it this weekend. Would like to have a surface to mount the filter minder on. Is there any problem with using one of the thick rubber reducers for drain systems as a connector between the turbo inlet hose and the BHAF in order to do this? Don't want to add something that could potentially damage the turbo.<br><br>CR
Old Oct 31, 2002 | 05:29 PM
chuck3's Avatar
Re:Installing new BHAF
Why do you even want it on? By the time the thing even moves the filter is so plugged you wouldn't believe it. ???
Old Oct 31, 2002 | 06:33 PM
DPG's Avatar
DPG
I don't know about the Cummins, but the NAPA 2790 needs a 4&quot;/3&quot; pvc adaptor to make it fit. And it doesn't seem to restrict airflow at all. I've attached a pic of my installation-hope that this helps.
DeWain
(I really need to proofread my posts)
Old Oct 31, 2002 | 06:39 PM
phox_mulder's Avatar
I think the main gist of his question is where to remount the filter minder at<br><br>I saw a pic of someone's installation where they put a piece of PVC pipe between the filter and the hose, then drilled a hole (can't remember what size) and put the filter minder there.<br><br>I personally don't think you'll even need the minder since you can see pretty clearly when the BHAF is getting dirty.<br><br>The reasoning behind the stock filter minder is Dodge doesn't want you opening the air box to check the filter, as that breaks the seal and unless you reseal it properly, crap can get in there.<br><br><br>Hope this helps<br><br>phox
Old Oct 31, 2002 | 07:31 PM
cr1998's Avatar
Thanks for the input guys. Actually I didn't mean a reducer, but a 4&quot; to 4&quot; section like Gear Poet mentions. Need to proof read my posts too, I guess. I should have just asked if the filter minder is necessary on the BHAF, and sounds like it probably isn't.
One more question though. Is moisture from splashing rain, etc. a problem in the area of the BHAF? I've seen someone's post of a cover or prefilter, but to me that looks like it would reduce the air flow some and defeat the purpose of the BHAF, JMHO.
CR
Old Oct 31, 2002 | 07:37 PM
When I get my BHAF I'm definately going to get the prefilter for it.<br>It doesn't cut down any on flow (not noticable by others who have it anyway) and not only keeps water off the filter, but fine fine dust as well.<br><br>Yes, some people have to put a piece of pvc, or other pipe into the neck of the filter to keep it from collapsing, cheap insurance in my opinion.<br><br>phox
Old Oct 31, 2002 | 07:45 PM
TxDieselKid's Avatar
I had a NAPA 2790 on for a year. I NEVER needed a PVC piece for it. Just took it off, and I had to use a metal coller on the new aFe. &gt;<br><br>Andrew
Old Oct 31, 2002 | 08:08 PM
RATTLINRAM's Avatar
I've got the Baldwin PA2820, which is the same thing and my turbo hose fit snug on the filter inlet. I didn't use anything in between the two. I have checked it after running in the rain all day and never seen it wet yet. I don't have the pre-filter on mine yet, but will get one in the near future.
As far as the Filter-Minder,,,,,,,,, I had a guy that works on them tell me, &quot;they weren't very accurate&quot;. Everyone that he had seen still read good when the filter should have been changed already.
Old Oct 31, 2002 | 08:35 PM
NWDave's Avatar
My 2790 required no adapters. Same fit as noobie Gear Poet's. Man, what a bummer. Having to start all over with the stars.<br><br>I ran the question about the outerwear and got back two significant replies. 1. Stay out of high pressure car washes and 2. He got alot of snow packed up in there. He musta been doing alot of four wheeling. As far as I'm concerned, the jury is still out for the type of driving I do (around the town and some freeway). If you stick in the turbo shield, that'll help give the compartment some protection as well because it surrounds both the bottom and the side next to the turbo. I don't really see too much road spray getting up in there. If and when it ever starts to rain again in Washington, I'll be keeping a close eye on it. Definitely will advise the board of my results.<br><br>Ain't that one big filter?? It just fits in the compartment. By the way, those studs that are left after you take out the stock box are 10mm. You need to know that to get a couple of nuts to anchor the turbo shield down. <br><br>Dave
Old Oct 31, 2002 | 10:27 PM
I thought the fleetguard had mesh outside and inside?
Or maybe it was the NAPA?
I can't remember.
phox
Old Oct 31, 2002 | 11:15 PM
BigBlue's Avatar
I bought mine from NAPA and it screwed it right in to the air hose. Fist like a glove.
