Installing 02 Cummins in a 98.5
Old Apr 17, 2010 | 09:20 AM
HtrsDesertRace's Avatar
Cracked block in my 24v 98.5, found a good deal on a 2002. Installed easily, but now has no power or acceleration (will start ok). Tachometer works for a few seconds, then drops to zero and the check engine light comes on. Surges horribly as well. I left the crank sensor connector loose (since the 02 doesn't have one), installed an 02 computer. I'm showing codes for a camshaft sensor (which I replaced) and 1693. I was told to replace the map sensor to a 2002 one and that should fix the problem. Just wondering if anyone else has done this kind of changeover and what else I need to do.
Old Apr 17, 2010 | 02:19 PM
can17's Avatar
Do you currently have the map sensor unplugged? Unplugging the sensor on a stock truck will result in very low power like you describe.
Old Apr 17, 2010 | 02:38 PM
Map sensor was plugged in but it was the 99 one, I haven't tried with the 02 map sensor yet.
12vchevydually
Jan 12, 2006 12:32 AM
cartuning.at
Feb 18, 2005 03:55 PM
ChrisLib
Dec 28, 2004 08:51 AM
ProjectM880
Dec 1, 2004 06:40 PM
Rammer64
Oct 7, 2002 07:17 AM
