Which Injectors??
Old Mar 19, 2003 | 11:01 PM
ungabunga's Avatar
Which Injectors??
I have a 98.5 24Valve, 5 speed<br>It has 4&quot; exaust, Superchips D-Box Chip and a Pyro and Boost <br>Guages on the a-pillar.<br>wanting to know which injectors to use and if I need anything<br>else with the injectors???
Old Mar 19, 2003 | 11:20 PM
atoughram's Avatar
Re:Which Injectors??
Any more injectors that stock, since you already have a fueling box, will leave you in need of a clutch. 275's would be a good choice, as would be DDI's - Higher than DDI's and you'll be looking for a new clutch and a different way to stuff air into the engine (turbo) for sure. Even with the PDR HX-35 I can peg a 1500 degree EGT guage quickly.
Old Mar 20, 2003 | 07:25 AM
hellotbone's Avatar
Might I recommend a clutch then get EDM's they are the new injector craze and look great I have a set and have noticed less smoke already. Don M a site guru has em forsale.
Old Mar 20, 2003 | 08:53 AM
Scotty's Avatar
Top's Younger Twin
[quote author=Jamie Attridge link=board=4;threadid=12514;start=0#118339 date=1048166756]<br>Might I recommend a clutch then get EDM's they are the new injector craze and look great I have a set and have noticed less smoke already. Don M a site guru has em forsale.<br>[/quote]<br><br>U got that truck on the road now Jaimie?<br>Is the snow gone there?<br><br>Its melting here fast...not long and it will be dry and then the spring heavy snow will hit. :'( :
Bradleysram
19
May 12, 2009 08:36 AM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
mcevins
Dec 2, 2003 11:38 AM
atc250r
May 12, 2003 02:56 PM
