Injector Knock????
Injector Knock????
I've only had my truck for about a month now and it has started knocking at a certain rpm. It does it througout all gears but not in nuetral just revving the engine. At starts at around 1400-1500 rpms and continues up. I thought it might be a spun bearing but at only 80,000 miles on the ticker it shouldn't be that, also I thought with the spun bearing it should be a constant knock regardless of rpm. I am at a loss right now, there are no codes thrown and fuel pressure is around 10-12 psi at idle and 7-8 at WOT. Im thinking maybe its time for some new injectors and hopefully not a new injection pump. Tomorrow I will be checking the valve lash to rule that out. Thanks in advance for the help guys.
I thought it might be nothing but it doesn't go away when the engine warms up, infact it gets worse. I plan on upgrading this truck soon and want everything mechanically straight before bombing. There is no powerloss, in fact I am really impressed how much pull this truck has for stock, fuel mileage is about 18mpg in city and 21-22 on highway. Maybe I should quit being such a Sally about my truck and let it rip,lol.
have you checked the valves to make sure that they don't need to be readjusted. it could be rocker knock. mine sounded like an injector knock but it is deffinitly the valves need adjusted
Look for excessive blow by or oil use like 1Q per tank could be a scored cylinder get a compression test and a oil analsis it will tell you if you have anything bad going on as well
usually I do not like to be a dooms day type but it happened to me Scored cylinder broken ring kept driving it (dumb) then dropped a valve
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
