improved mileage question
Old Jun 18, 2005 | 12:46 PM
Ian's Avatar
Ian
I think this has been covered before, but I did a search and came up dry. I'm getting about 400mi on a full tank, and I'd like to see a bit more. What can I do to improve my mileage? I'm planning on getting an edge comp and doing an oil change pretty quick. Would changing the type of oil I use show an improvement?
Thanks!
Ian
Old Jun 18, 2005 | 03:09 PM
Topper's Avatar
Ian,
I run full synthetics in my crank case and rear ends. I can say for sure that it would help you to switch, but I'm sure it wouldn't hurt. By the way I get about 600 miles to a tank full (20mpg)and I fill up about every other day. I do alot of driving on the thruway and the cruise is set at 75mph all the time. 3.54 gears and 245's
Topper
Old Jun 18, 2005 | 03:35 PM
graphitecumnz's Avatar
Re: improved mileage question
Thanks!
Ian
what type of driving are you doing??? 400 per is pretty low considering a stock truck... with my mods I still get 18-20 mpg depending on my driving style.
the best ways to improve mileage are too keep your RPM's in check and don't race stoplight to stoplight. also, check your filters... fuel and air... wouldn't be a bad idea, actually preferable, to get some gauges before you toss on that Comp.
Old Jun 19, 2005 | 10:51 AM
Ian's Avatar
Ian
I just changed the air filter, no idea about the fuel filter, and I'll try those synthetics next time they're due for a service. I'm running 33s too. I didn't think that my style of driving would affect my mileage that much, but I guess I'll tone it down a bit its just so much fun ripping around
thanks guys,
Ian
Old Jun 21, 2005 | 12:19 AM
GlennRMK's Avatar
Also, with larger tires, you are going more miles then is indicated by the odometer.
Mileage may not be as bad as you thought.
Old Jun 21, 2005 | 12:41 AM
AAmeeting's Avatar
2x4 under peddal
Old Jun 21, 2005 | 07:39 AM
Ian's Avatar
Ian
GlennRMK:
how do I adjust the odom/speedo to account for the 33s?
Old Jun 21, 2005 | 02:26 PM
RowJ's Avatar
....how do I adjust the odom/speedo to account for the 33s?
Correcting speedometer has to be done by dealer....but you can correct your mileage by adjusting (adding) miles to those registered on odometer through chart on this web site....
http://www.sjdsm.com/tech/tire_size.htm
My Michelin 285/75/16's are listed at 32.8". I add 3.5% more miles to my odometer reading before dividing by # of gallons.
But my truck came with 265's. If yours were 245's...you will be adding a lot more miles (over 7%)!
After correction...I got about 18.3 mpg average on last 1,000 mile check.
Good Luck
RJ
Old Jun 22, 2005 | 09:09 AM
Ian's Avatar
Ian
ya, mine came with the 245's originally. After the correction, it turns out that I drive an extra 40 miles or so. very interesting! thanks,
Ian
supr
May 8, 2008 07:16 PM
Slo'n Down
Apr 26, 2006 10:42 PM
Matt400
16
Aug 3, 2004 10:41 PM
Mark Thomas
Jul 2, 2004 08:31 AM
cubcp
May 3, 2003 12:02 PM
