Idle?
Old Aug 19, 2008 | 10:27 PM
big wally's Avatar
Idle?
What would cause the idle, to stick at 1000, after a 90 minute drive on the highway.
New VP44 and good fuel pressure.
Could it be one of the sensors?
She usually idles at 850.
As this is my first computer driven CTD, (lots of 1st gens), I may have a few questions.
Thanks Guys.
Old Aug 23, 2008 | 04:33 PM
dozer12216's Avatar
Possible linkage is sticking slightly? can you play with linkage and get it to drop?
Does it drop down on it's own after a bit? Any codes?
Is it quite hot from a heavy pull?
Old Aug 23, 2008 | 06:57 PM
Tate's Avatar
My truck with the HRVP did this quite a bit. New APPS never changed it anything. Different Smarty settings never changed it. When you start to engage the clutch in gear, does it drop right back to where it was supposed to be (800ish RPM)?
Old Aug 24, 2008 | 12:44 AM
big wally's Avatar
idle
Reset APPS, this seems to have helped.
Supply pressure, 13 psi @ idle, 8 psi @ wot.
New pump.
Next, will check the injectors, pop test them.
What else could it be?
Have been asked if this happens, do I have the air conditioning, on?
What would that have to do with it?
Thanks guys.
BW
Old Aug 24, 2008 | 01:23 PM
Tate's Avatar
A/C will put a load on it. I was able to bring the idle down just by standing on the brakes hard, as it would make the power steering pump work harder.
Ram1999
Feb 11, 2007 10:49 AM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
