IAT Sensor
Old Nov 27, 2008 | 12:03 PM
DodgeCowboy's Avatar
DTR's Cow Boss
IAT Sensor
Would a bad IAT sensor not allow the high idle to kick on? This is the last thing I have yet too test too see why its not coming on even thought its turned on. Also I messed with the set screw for the throttle cable is there a right and wrong spot for it?
Old Nov 27, 2008 | 12:21 PM
klx650a2's Avatar
Yes, a bad IAT sensor would cause it to not kick on to high idle. Don't know about the set screw. I also just made my own high idle so it comes on when I want it. Great for winter warmup and summer cool down.
Old Nov 30, 2008 | 11:13 AM
DTR's Cow Boss
Well here is what I found out. I went out side and yanked the IAT out again its been maybe 15 thousand or more since I cleaned it last and well what do you know it was pitch black darker than the inside of a boot could not even see a spot of white let alone the little diode in the middle of the sensors cadge. Now what was what I thought due too not being chipped my lower than normal mileage might make sense and it has seemed down on power. I can only believe that this was the reason it was not coming on and I think it fowled faster because the chip was failing and could have been over fueling every thing. Plus I use my exhaust brake allot also. Waiting for another cold snap.
scottboy69358
Jul 4, 2013 02:05 AM
supr
18
May 21, 2007 09:29 AM
Shepherd57
May 5, 2003 05:04 AM
TX Ram
Feb 26, 2003 10:38 PM
bkay
Jan 17, 2003 03:30 PM
