IAT Sensor
Old Feb 11, 2008 | 01:24 PM
farmer13's Avatar
IAT Sensor
How does one check the IAT sensor to know if it is working properly?
I read that if it doesn't read temp right you can use more fuel hence poor
fuel economy and higher EGTs.
Old Feb 11, 2008 | 07:41 PM
danalex's Avatar
Here's a couple links I found useful for checking the IAT; I basically took mine out and cleaned it off...it wasn't very dirty and I didn't have a problem, just felt like PM'ing.
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
http://dodgeram.org/tech/dsl/sensors/IAT/clean.htm
http://www.smokindiesel.com/Technical.htm
-d
Old Feb 11, 2008 | 10:11 PM
afoulk's Avatar
yeah, I did the same to mine last week. Took it out and cleaned it, but it wasn't really all that dirty. Havn't noticed any difference in fuel mileage or performance after doing it either. I think it would have to get pretty cruddy before it would affect performance.
Old Feb 12, 2008 | 07:42 AM
farmer13's Avatar
thanks for the info, will try that to see how dirty mine is. Have 193000K on my truck
Old Feb 12, 2008 | 09:18 AM
JSPulliam21's Avatar
You can pull the sensor and ohm it out at different temps to see if it is reading correctly. I do not know the specs, though I remember seeing them somewhere on one forum or another. Mine was pretty nasty when I cleaned it the first time, but 20k miles have not done much to it.
Old Feb 12, 2008 | 10:20 PM
NoSeeUm's Avatar
Give or take:
Temp Res
30 40000
32 34000
76 13000
77 10000
81 6870
122 3000
130 4000
167 675
212 600
Jim
Old Feb 13, 2008 | 07:43 AM
Well, there you go. Thanks, NoSeeUm.
Old Feb 14, 2008 | 03:09 PM
BlackCloud#2's Avatar
Has anyone pulled their map sensor out and cleaned it? Also did it change how the pickup ran?
Old Feb 14, 2008 | 03:13 PM
What size socket does it take? I may try that this weekend.
Old Feb 15, 2008 | 10:08 PM
afoulk's Avatar
One guy on TDR said he used a 22mm socket to get his off, but another said that didn't fit, but a 13/16" sparkplug socket fit perfectly. I honestly can't remember what I used.
Unless its gummed up something fierce, I don't think there would be much advantage to cleaning the MAP sensor. Its basically just a sensor with a diaphram in it, with a port in the end for the boost pressure to enter the sensor and push against the diaphram. So unless that hole is clogged, I don't think cleaning it will do much.
Old Feb 16, 2008 | 01:44 PM
I meant MAP sensor, but your explanation of the way it works makes me think a cleaning would be a waste of time. Thanks.
Old Feb 16, 2008 | 01:50 PM
dj_souvlaki's Avatar
well currently at my shop. lots of gm customers looking at me weird. actually in the process of removing and cleanign it with 146 km on it
Old Feb 16, 2008 | 02:22 PM
alright removed it. piece of advice for people. buy a pick with a 90 degree bend at the end for removing the sensor clip. after you get the connector off. one website calls for a 13/17" socket. very tight fitting. 22 mm is too big. 21 mm is loose fitting but works the best. i removed my dip stick tube to make it easier.
if you have huge forearms like i do i wish you the best of luck. very very very tight space.
so i cleanedit off but with 146 km on it it was very clean. we will see how my miallege is effected.
Old Feb 16, 2008 | 02:59 PM
I feel your pain
Old Feb 16, 2008 | 06:32 PM
Originally Posted by JSPulliam21
I feel your pain
i can't change the oil filter on a 2200 powered cavalier/sunfire. my forearm wont fit it is impossible
