I thought silencer ring was easy?
Old Dec 20, 2004 | 10:19 PM
Eatmup's Avatar
I haven't been able to get the outer(gray) ring to budge. I've used several different small and large screwdrivers. What am I doing wrong? Thanks for your help. Chris
Old Dec 20, 2004 | 10:22 PM
MNorby's Avatar
I is just like a snap ring holding the locking hubs into the bearing hub on old front ends. On the endof the ring ther is a small indention where you put a small screwdriver in and turn and pull it up then take another small screwdriver under the ring and pry it out. Kind difficult the first couple times till you really get a feel for it
Old Dec 20, 2004 | 10:24 PM
Eatmup's Avatar
I tried that but I'll try again and hold my mouth right. Thanks
Old Dec 20, 2004 | 10:45 PM
Eatmup's Avatar
I got it, the problem was the indention was at the top and it was hard to see to get the other screwdriver in. Thanks
Old Dec 21, 2004 | 02:45 AM
willysrule's Avatar
I took mine and drilled .055" holes for snap ring pliers....just incase I put it back in...
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
