I need a LS posi. 2nd Gen
Live up in Alaska and need a LS posi. Currently truck does't have one and I'm not getting enough traction to go. If any of you guys and gals took one out to replace with a locker, I'll buy it for a descent price even if it needs rebuilt.
Dana 70 3:55 gearing.
Sure you don't have a LSD?? Very unusual to see an 02, 4x4 without. Especially in your state....no?
Many have assumed they did not have a Limited Slip, only to discover it wasn't working right!
RJ
RJ
Not sure if you want a full locker in the snow but a Detroit locker is an easy and low cost ($300.00) option if you have an open Dana 70 or 80.
You probably do have a limited slip.
The Dana 70 will have a Powerloc and the Dana 80 will have a tracloc.
Both are rebuildable.
The Powerloc is the stronger and better of the 2 ls units.
Both can be shimmed tighter to give better traction.
Ran the Vin past the dealer and open rearend. I don't want a Detroit locker up here the roads are bad and I've seen Lockers push trucks off the road. I'll take the limited slip. I'm looking for the Powerloc
BRUISER
Feb 2, 2015 11:25 AM
jmccart
Jul 10, 2007 11:46 AM
jmccart
Jul 7, 2007 12:46 PM
