Hurt my 01 Engine?
Old Sep 13, 2011 | 05:03 PM
patdaly's Avatar
Tensioner assy will come with a new idler and bearing. While you have it apart ( belt off ) make sure you don't have slop in the water pump and fan support. I know you just replaced the WP, but it is a free thing to give it a wiggle just to be sure. If your fan support brg. is bad, you can replace it without replacing the whole unit.
BTW, make sure you get the best tensioner assy you can find, even the good ones have had some spotty quality.
Old Sep 13, 2011 | 09:52 PM
wlowe's Avatar
Originally Posted by ranchertx
I was driving the hwy this morning with a 25' trailer, and the AC quit cooling. Then I noticed a light on "Check Gauges". I looked and the temp was pegged at 240.
This is one reason why I purchased an Edge Juice W/Attitude. I have it set for an audio alarm when the engine coolant temp hits 210 degrees. I believe the Edge Insight does this also. It's very easy to not notice the engine temps until they are very hot. The audio alarms make for a more enjoyable ride since you don't have to watch the guages all the time.
Old Sep 14, 2011 | 05:50 AM
ranchertx's Avatar
What brand do you recommend? O'reilley has Gates. It is American made. Think it is good?
Old Sep 14, 2011 | 08:06 AM
patdaly's Avatar
Gates is as good as it gets, short of Cummins. I can say this, all our old line Mfgs. are not what they once were. Look your part over carefully and you should be good.
ron b
21
Oct 2, 2008 07:27 PM
FSTDL
Aug 18, 2008 05:36 PM
hillbillymudrun
Jul 3, 2007 09:24 AM
MNorby
Jan 24, 2006 07:19 PM
Bad Ramer Jamer
Dec 12, 2005 01:01 PM
