How to tell if you have a bad thermostat?
Old Jan 29, 2003 | 07:46 AM
Jones0027's Avatar
Diesel Gods,<br> I've noticed my temperature gauge takes a while to get to 180/190. Since the weather warmed a bit from the freezing temps we've had in the past week, my temp gauge takes longer to get to the normal 180/190 range. I warm up the truck about 5 to 10 minutes everyday no matter what the temp is outside. I drive 37 miles to work on interstate highway and it takes a good 10 miles at 70mph to get to 180/190. I'm wondering if my thermostat is bad? :'( Thanks. ;D <br>
Old Jan 29, 2003 | 10:33 AM
fj40charles's Avatar
Re:How to tell if you have a bad thermostat?
Based on the history and many folks having problems (myself included), I'd check the thermostat. Mine had the lower leg broken on the thermostat and it took forever to heat up.
Old Jan 29, 2003 | 11:40 AM
KennyM's Avatar
I just replaced mine, Lower leg also broke. I had the same issue, took forever to come up to temp.
Old Jan 29, 2003 | 12:53 PM
Marine's Avatar
Veteran: Marine Corp
What thermostat did you use? stock, or aftermarket?<br><br>Mike
Old Jan 29, 2003 | 01:16 PM
Jones0027's Avatar
[quote author=Marine link=board=4;threadid=10230;start=0#97919 date=1043866403]<br>What thermostat did you use? stock, or aftermarket?<br><br>Mike<br>[/quote]<br><br>Stock Thermostat.
Old Jan 29, 2003 | 02:06 PM
Mule Skinner's Avatar
DC has a TSB for thermostats for 98-02 24 valvers. TSB number 09-008-02. The thermostat will make a fluttering noise pulling heavy loads up hill. Might be worth having checked out.
Old Jan 29, 2003 | 02:26 PM
Pit Bull's Avatar
Your wasting your time warming it up for 5 - 10 minutes. You would be better off plugging it in, anytime the temp gets below 40 degrees. Plug it in for at least 2 hours. They warm up when you drive them. If I plug mine in for 2 hours, start it up and drive away within 2 minutes it will be warmed up within 5-7 miles of driving. I think yours sounds close to normal.
Old Jan 29, 2003 | 02:52 PM
99 guy's Avatar
Ditto here: another lower leg broke
Old Jan 29, 2003 | 04:50 PM
Marine's Avatar
[quote author=Horse Hauler link=board=4;threadid=10230;start=0#97944 date=1043870796]<br>DC has a TSB for thermostats for 98-02 24 valvers. TSB number 09-008-02. The thermostat will make a fluttering noise pulling heavy loads up hill. Might be worth having checked out.<br>[/quote]<br><br>Look at this: NOTE. 05015708AC (thermostat part #) IS TO BE USED EXCLUSIVELY FOR THIS SERVICE BULLETIN. USE THERMOSTAT 05015708AB (thermostat part #) FOR ALL OTHER 24 VALVE CUMMINS THERMOSTAT REPAIRS NOT RELATED TO THIS BULLETIN.<br><br>What do you think the difference is?<br><br>Mike<br><br>
Old Feb 23, 2003 | 09:03 AM
tomrock's Avatar
[quote author=Marine link=board=4;threadid=10230;start=0#98013 date=1043880652]<br>[quote author=Horse Hauler link=board=4;threadid=10230;start=0#97944 date=1043870796]<br>DC has a TSB for thermostats for 98-02 24 valvers. TSB number 09-008-02. The thermostat will make a fluttering noise pulling heavy loads up hill. Might be worth having checked out.<br>[/quote]<br><br>Look at this: NOTE. 05015708AC (thermostat part #) IS TO BE USED EXCLUSIVELY FOR THIS SERVICE BULLETIN. USE THERMOSTAT 05015708AB (thermostat part #) FOR ALL OTHER 24 VALVE CUMMINS THERMOSTAT REPAIRS NOT RELATED TO THIS BULLETIN.<br><br>What do you think the difference is?<br><br>Mike<br><br><br>[/quote]<br><br>Good question, anyone know?????
Old Aug 29, 2008 | 08:21 AM
Marine's Avatar
bringing this one back up.
Bookshelf
May 30, 2009 01:17 AM
3592788
Feb 2, 2008 02:12 PM
Guardrail
Oct 29, 2006 04:03 AM
SuperDave4x4
Jul 12, 2005 11:59 AM
Nimrod
Dec 30, 2003 10:06 AM
