How much smoke is too much?
Hello, not sure if if I have a problem or not. I have 2002 H.O. .<br>Only added K&L air filter. It has 18000 miles. When I accelerate to merge into traffic, it blows a lot of black smoke Not sure if it should smoke that bad or not. Any ideas will be great.<br> <br><br> Thanks
Re:How much smoke is too much?
Mines not a HO, but I've never seen black smoke come out of her (him?).<br><br>I can "haze" the traffic behind me if I really romp on it, with light gray smoke.<br><br>I'd have to second the low boost.<br>Check your intercooler boots, hopefully one of them is loose and it's not a turbo problem.<br><br>Judging by your sig, you shouldn't have a problem with the dealer if it is a turbo problem, as long as the K&N (K&L?) didn't deposit oil on the turbo blades, and you remove it before taking it in.<br><br><br>phox
[quote author=98rammer link=board=4;threadid=16759;start=0#157304 date=1057554153]<br>boost leak? i doubt it. it's the high elevation. the HO's smoke decent for a stock truck....more than the ETC's up here at 7000+ feet. don't worry about it. bad air!
<br><br>Tom<br>[/quote]<br><br>I agree, I smoke a lot more up here then I did back in Iowa, and my truck is bone stock except for a BHAF.
If you can see the guy behind you when you accellerate then you don't have too much smoke..
When I go, it's like a solar eclips, day to nite, blackout, forest fire,...stealth mode.
;D ;D<br><br>Steve
;D ;D<br><br>Steve
From: Land of Oil Wells, Sooners, and No-blinker using fools
Gee thanks for triggering my paranoia, guys!! I just had a similar event take place with the wife's HO.<br><br>I was pulling the fiver through OKC traffic yesterday, and noticed the following:<br><br>Outside temp was 97 and muggy<br><br>Speed - increased from from 55-65 in 6th gear, nearly floored the accelerator<br><br>Boost - climbed to 18 or so<br><br>No smoke until I backed off the accelerator pedal - then nice big cloud of black smoke - my wife noticed it two cars behind me.<br><br>Constant speed/accelerate is clear - releasing acclerator shoots puff of black smoke - does this seem normal?<br><br>[move]The signature line shows all the toys - no fueling boxes, air boxes, etc.[/move]
How much smoke is to much? When you can't see the intersection that you just went through, then you have JUST enough. ;D Seriously though, my truck with a Comp in EZ mode and on 5x5 will put a decent (for a stock truck that is) amount of smoke out from a light and will have the slightest haze from there on out. It clears up quick though.
jjrightmire1973
Nov 20, 2008 08:20 AM
