how to identify axle type?
Help,
Need to replace the rear axle seals on my 1999 4x4, and need to identify the type of rear axle.
Last 9 digits of VIN are 1XG148053
Is is the 248, 267 or 286 axle?
Thanks
Mike
Thanks
Mike
I have not used vin. code for axials , the tag on diff. cover is one way , but I think there are only 2 to chose from , the Dana 70 or the Dana 80 .
to help , more info on your truck , 3/4 or 1 ton .
Also what I did when I got my truck [ used / 2nd hand ] was to go to the dealer with the vin. code and ask for a build sheet , then you do not have to look for info every time you need something and it is specific to just your truck .
3/4 ton
Stamp on the Diff cover is:
43293 2
240 8
There is a band that is on the diff cover on the two left side bolts
Numbers on there, but only partially readable
Trying to find the right bearings and axle seals
Thanks
43293 2
240 8
Thanks
I have a 99 8800GVWR with the DANA 70 on the REAR. it's a limited slip diff mine.
look at the VEHICLE EQUIPMENT TAG on the underside of the Hood, near the back of the grille! it's write there.
bigragu
Oct 2, 2014 01:28 PM
horselady
Dec 19, 2010 09:32 PM
kram
Aug 29, 2007 11:01 AM
Dave88LX
Aug 31, 2005 09:52 PM
