How do you find boost leak?
Old Dec 5, 2006 | 09:34 AM
4x4dually's Avatar
Any slick ideas on how to find a boost leak?
Is there any way to 'charge' up the system and find them? I was thinking about taking the tube off my turbo and making a big plug and putting an air valve on it so I can charge it up to say 20 or 25 psi and then I can spray soapy water on the boots and find leaks. My truck seems to release boost after I hit 20 psi now.
Does anyone think that will work?
Old Dec 5, 2006 | 09:37 AM
displacedtexan's Avatar
It should work. I believe that is how most people do it.
Old Dec 5, 2006 | 09:40 AM
4x4dually's Avatar
How do most folks make the plug, any ideas? Wood or steel?
Old Dec 5, 2006 | 09:43 AM
I don't think it would matter, whatever would be easier for you.
Old Dec 5, 2006 | 10:17 AM
volly818's Avatar
try using pvc. you can get end caps that should slide right in the end of the hose.
Old Dec 5, 2006 | 10:22 AM
4x4dually's Avatar
Brilliant! That sounds even easier! Thanks. JWB
Old Dec 5, 2006 | 10:28 AM
scottsjeeprolet's Avatar
Look in the tech section under General and there are instructions on how to make one, i used PVC, just took my stock turbo inlet elbow into Lowes and found a pvc piece to fit in it.Plugged it tapped it and put a guage with valve on it.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Dec 5, 2006 | 12:39 PM
johnh's Avatar
pvc fittings from home depot
Old Dec 5, 2006 | 12:51 PM
4x4dually's Avatar
Thanks a bunch. That is perfect! I'll be making one of these.
Old Dec 10, 2006 | 12:03 AM
Sea Bass's Avatar
I made one out of pvc. It works pretty well up to about 10psi but the stock intake tube expands like a balloon and the plug blows off. BE CAREFUL!!!
I need to find a better way to adapt the plug to the turbo.
Old Dec 10, 2006 | 12:25 AM
J BODY's Avatar
The tester for that issue is in my pictures......
Old Dec 11, 2006 | 08:16 AM
4x4dually's Avatar
Ok. I built a tester. Sea Bass is right, once I get to 5 PSI, that POS shots off the turbo. I realy love how II didn't spend the extra money to machine the outside of the intake port. It is rough and won't seal and there is no way to keep that adapter on there. So, the tester idea was a total failure. I got a wrench and tightened every clamp on the system. To my surprise, I could turn the nuts 3, 4, 5 or more times. They were SO LOSE! My problem is now NON-EXISTANT! I can hold 40 PSI now and it runs like a champ again.
Thanks for all your input. The tester is great, but really stinks! I have feeling if I were to get it to 20 PSI it would have thrown the test jig clear through the barn wall!
RV2
May 17, 2009 10:12 PM
Erska
Jan 13, 2007 12:48 PM
imabnormal
Jun 26, 2006 08:02 AM
j-dubya
19
Oct 21, 2005 05:50 AM
95ram
Aug 9, 2005 08:00 AM
