How do I clear Error Messages
Old May 31, 2008 | 11:29 AM
Doug Crall's Avatar
I posted here a while back that my 2001 acted like it was occasionally starving for fuel, It acted like it had a bad fuel filter or had a bit of water in the fuel. Many of you suggested replacing the lift pump, I just installed a Raptor and when I first left the drive way it acted as if it was starving as before, I am hoping it was maybe a little air in the new system that has blead out. After a few blocks it cleared up, I have about 10 in town miles on it and it seems ok. If this wasn't the problem, I am open to other suggestions.
Before I take it out again I wanted to clear the 2 error messages to make sure all is ok.....How do you do that???
As always your help is appreciated.
Doug
Old Jun 3, 2008 | 06:04 PM
rollcage's Avatar
there may be another way, but if you remove the battery cables and then turn the ingniition to on for 30+ minutes it will drain the capsitors and reset.
I did it to reset the APPS, and it reset everything.
BigBlue
17
Jun 6, 2007 12:16 PM
TxDieselKid
Dec 19, 2003 09:11 AM
