How to Crack and Bleed Injector Lines
Old Aug 6, 2011 | 01:39 PM
1-5-3-6-2-4's Avatar
:shrug: I dunno. I could litterally kill my engine on demand that way. With hrvp, fass, full 1/2" fuel lines, no banjo bolts, ddp comp 250s.
Sent from my Desire HD using Tapatalk
Old Aug 7, 2011 | 01:11 AM
totalloser's Avatar
Air CAN NOT bleed back into the injector from the cylinder unless it is BADLY damaged.
Injectors CAN NOT use more fuel than the vp delivers. They would close LONG before the pressure dropped since the pressure created by the vp is what actually opens the injectors.
The injectors on the vp44 trucks are "auto bleed" type that release some fuel back to the tank on every injection cycle to purge excess air. If you are getting air in your high pressure system- enough to cause a problem, there is a VERY serious air leak into the low pressure fuel delivery system.
Bad Ramer Jamer
13
Jan 12, 2008 05:38 AM
betsycam
Jul 25, 2007 08:08 AM
DL1221
Nov 28, 2006 08:18 AM
aicomp
Nov 6, 2006 01:03 PM
debolton
24
Jun 29, 2004 09:22 PM
