Holset H35W Question only 14lbs? Normal?
Old May 21, 2007 | 09:55 AM
jdr160's Avatar
1999 Dodge Ram Cummins 24v with <93K miles. What is the boost suppose to be? According to my autometer (which is tapped in at elbow on top) I am only getting 14LBS Max. Did I not tap into the right place or am I losing boost somewhere? Anyone have any ideas?
Jared
Old May 21, 2007 | 10:19 AM
fbgdiesel's Avatar
Is that the max you are getting out of it? mine runs about 6-8 on the highway and when i really get on it i run about 24-25 hauling a trailer. hope this helps.
Old May 21, 2007 | 10:21 AM
fbgdiesel's Avatar
as far as tapping it i have no idea but i think you should be getting more than that.
Old May 21, 2007 | 10:55 AM
jdr160's Avatar
14 is the max with or without a trailer. Yes, it deos seem a little low.
Old May 21, 2007 | 11:09 AM
starkey's Avatar
yeah. check your elbows at the intercooler and such, mine had a hole at the boot on the passengers side at the intercooler.
Old May 21, 2007 | 11:15 AM
fbgdiesel's Avatar
yea check your hoses, but yea something isnt right it should be pushing more than that. How much boost do u run driving down the highway?
Old Jul 20, 2007 | 10:57 AM
redneck_racer's Avatar
Your boost gage should be hooked in on the drivers side of the block there is a connector that hooks under the fuel rail between 5 and 6 cylinders that gives you the boost pressure in the intake. also you might want to change your elbow on the turbo that feeds the waste gate that will also give you more boost pressure.
Old Jul 20, 2007 | 12:20 PM
R.T.D.H.S.P.'s Avatar
You won't see anymore than about 17-19 tops without fueling additions (especially with the automatic). The HY-35 turbo on the autos normally top out at around 18-19 psi unless you have a j-hook or turnbuckle on the wastgate lever.
35psitsi
18
Jun 23, 2007 04:58 PM
toyota31
Dec 22, 2006 11:55 PM
turbo2001rt
Nov 20, 2006 02:11 PM
fahrfrumwurkin5
Mar 13, 2005 03:38 PM
fahrfrumwurkin5
Jan 8, 2005 04:28 PM
