High spool whine?
Old Oct 10, 2006 | 09:16 PM
dutchboy's Avatar
High spool whine?
Yesterday on my way home from hunting I noticed a high pitch whine when the turbo starts to really push some air. In the early stage of spool I get the standard whistle. Any ideas?Also when I roll up to a stop it idles @950 then when I stop it drops off to 900.
Old Oct 11, 2006 | 08:03 AM
volly818's Avatar
Do you loose any power? sounds like a boost leak to me. Check all the intercooler boots for leaks.
Old Oct 11, 2006 | 08:09 AM
Hillcountry's Avatar
If you are really honkin' on it it will whine and sometimes you will hear the exhaust resonate at a high frequency...a boost leak will be a wooshing sound. The RPM drop is common. The brake booster is run off a pump in the timing gears. To maximize braking power, the engine idles "high" and then drops when you come to a stop. Mine goes between about 900-850 or so. I think what you are hearing is normal.
With the boost whine...if you are losing power something is leaking...if you are flooring it, it is probably normal. Check your air filter maybe it is leaking.
Someone will chime in if I am wrong about the idle thing...I read that here somewhere.
-Geoff
Old Oct 11, 2006 | 09:08 AM
Mopar1973man's Avatar
Hillcountry is right on...
Mine idles the same way when rolling up to a stop then drops the extra little bit...
As for whine noise... Check you intercooler boots of holes. Do you have a boost gauge at all??? It might help find you problem...
You might also inspect your turbo for damage too...
http://www.frontiernet.net/~mopar1973man/turbo.htm
Old Oct 11, 2006 | 10:42 AM
dutchboy's Avatar
I loose no power ,I just had the truck out and it sounds like it is coming from the drivers side. Is it at all possible it could be the LP on its way out and the ECM is compensating for it causing the change in idle?
turbo246
Jul 17, 2016 09:35 PM
airplaneman00
20
Jul 17, 2016 09:19 PM
janb
Jul 29, 2007 02:44 PM
sintax
Mar 21, 2006 12:53 PM
akapun
17
Nov 16, 2004 08:37 PM
