is it to high of a price
Old Aug 19, 2005 | 06:05 PM
torque6's Avatar
Question is it to high of a price
i found an 01 2500 reg cab ctd 4x4 5 spd. it has 113k miles and two small dents. the guy is aking $17,000. is he asking to much and what should i offer. it has some power uprades all so. thanks
Old Aug 19, 2005 | 08:33 PM
tthomass's Avatar
2 things for advice that i use:
1st.............. go to www.kbb.com and check out its value
2nd............go to www.autotrader.com and see what otehrs are go'n for
2 min on #1 and about 15 on #2 and you'll have a good idea on the price..........hope this helps
Old Aug 19, 2005 | 11:06 PM
Supermod56's Avatar
That's not overly high, check it to make sure it doesn't have the dreaded "53" block, left front of the block right above the oil pan you will see a 1" tall #. Find out if it has towed any serious weight, gooseneck ball, etc. If it has, keep looking, the 5-speed is probably ready to pitch 5th-gear out. Probably will need a clutch if it's never had one put in also.
Tom
Old Aug 20, 2005 | 02:12 AM
torque6's Avatar
I've looked on auto trader and its about 1 to 2k high but it is only about an hour away and the others are about 2 or 3 states away. i'll check kbb. it doesn't have a gooseneck ball and it has a heavy duty clutch with about 25k on it. haven't yet but i sure will check to see if it has the 53 block. i thought it was a little high. thanks
crobtex
49
Mar 28, 2012 10:13 PM
Deer716
Oct 5, 2004 09:29 PM
BCarmicle
Sep 22, 2004 12:10 PM
klrmark
Sep 4, 2003 09:37 PM
