Help!!! What is up with this?
Old Sep 17, 2007 | 12:31 PM
R.T.D.H.S.P.'s Avatar
Hope someone can give me an answer. Here is the problem: At anywhere from 30 mph to 70 mph I'm getting a 200-300 jump in my rpms and a bucking feeling when this happens, almost like I'm running out of diesel. I had the problem before but then it went away and ran fine. I installed a BD low fuel pressure light. When I did the install and got everything hooked up, the red light would not go off. So to NAPA I went to get another lift pump (Carter). Bam, the red light went out, 0216 code that I had before disappeared. Problem solved! Nope! Ran like a scalded ape for about a week. Then, back to the same old thing. The bucking is back and gets worse each day, and every now and then the red low fuel pressure light will blink fast a couple times, but it never stays on, even at WOT!, and the 0216 code is gone. However, sometimes it doesn't do it and runs fine. Other times its so bad I wanna run it off a cliff. I'm just confused being that the 0216 code went away. I thought IP but I've also heard talk about the APPS going out and causing some of these symptoms. The only code I show now on the 3 turn key trick is P 0122 (TPS voltage low). So what do I do? Is it the IP, the APPS, both, neither? Someone please help. Thanks in advance.
Old Sep 17, 2007 | 12:50 PM
Tocapet's Avatar
Try resetting the APPS and see if that cures it.
Old Sep 17, 2007 | 12:58 PM
BIGBEN's Avatar
Try re-calibrating your APPS. how to do so can be found on this link
https://www.dieseltruckresource.com/...ght=APPS+RESET
Old Sep 17, 2007 | 01:59 PM
Ok. I tried the reset with no luck. Now I'll try the recalibration for the voltage. Thanks guys.
Old Sep 18, 2007 | 12:27 PM
SIXSLUG's Avatar
Could be IP, or bad fuel. Check filter and water separator first....cheap and easy. Do you fill up at the same place every time? Just a thought, I got a bad tank of fuel last fall and was up in the high country when my truck felt like it was missing, all I could think of was how much it would cost to tow it down the mountain if my ip went out. Turned out to be water in fuel. Just a thought. Kurt
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
