Help mpg frustration
Old Feb 20, 2010 | 11:48 PM
kicker210's Avatar
The truck in my sig is my daily ride, a year ago I was going 450 miles and refueling and only using 25 gallons. And now I can't even get my mpg over 14.0mpg no matter what I do I drove about 300miles this weekend and no rise and that's at 65-68 cruise on and running empty.... My lift pump is just at a year old the injection pump is right at two years, I drive easy no hard driving and hasn't towed anything in quite awhile. But this fuel mileage is driving me crazy. So any and all thoughts and ideas would be great I need help!!!
Old Feb 21, 2010 | 12:14 AM
rebal's Avatar
try cleaning you map and IAT sensors if that dont help replace them.
Old Feb 21, 2010 | 12:18 AM
kicker210's Avatar
I cleaned iat and I'm not sure how to get the electric plug offthe map or what size or anything the map is. And another thing to add is the performance hasn't seemed to change in the truck unless it's been so gradual that I haven't been able to tell idk
Old Feb 21, 2010 | 10:40 PM
dozer12216's Avatar
Winter fuel with high mix of #1 diesel and anti gel additives are probablly killing you. Also the USLD fuel seems to have fewer BTu's of heat engery than old LSD fuels. Milage should improve as winter blend phased out for summer blends.
Old Mar 20, 2010 | 07:10 PM
totalloser's Avatar
I would consider some fueling mods. I'm sure the cold weather is hurting your efficiency, but your mods are very similar to what mine were at one point, and when I added sticks, I got an extra 1.5 to 2mpg and was able to keep my rpm's lower.
A EZ would probably be a better bet, though since it will give you more low rpm fueling, AND some timing. I bet you'd get more than I got from my sticks. I only recently added the chip, and haven't done any efficiency calculations yet. I expect a small increase-but only from the timing.
Fuel filter dirty maybe, too?
Yellow Yota
Jul 15, 2008 06:43 PM
oaborbag
May 26, 2008 10:34 PM
chuxtruk
23
May 13, 2007 11:37 AM
Copenhagenjunkie
Jun 4, 2005 09:40 PM
AlpineRAM
13
Apr 4, 2005 01:21 PM
