Help me find my oil leak.
Old Aug 11, 2006 | 05:47 PM
dieselfan's Avatar
It looks like its coming from the power steering pump. It only leaks sometimes like when its real hot or i run it hard. Sometimes it will be a couple drops or if i run a store for 5 -10 minutes it will leave a 5" puddle. I just cant tell where its coming from. Please help dieselfan.
Old Aug 11, 2006 | 05:50 PM
nitrousn's Avatar
did you remove and clean the blow by bottle?
Old Aug 11, 2006 | 05:52 PM
Silverjay's Avatar
Sounds like you vaccum pump. Check out fixinrams.com. He has rebuilt pumps or a rebuilt kit for much less than a new pump.
Old Aug 11, 2006 | 05:55 PM
dieselfan's Avatar
[QUOTE=nitrousn]did you remove and clean the blow by bottle?[/Q
i dont have a bottle just a hose extended along the frame.
Old Aug 11, 2006 | 05:59 PM
dieselfan's Avatar
thanks, that seal that fixinrams sells just might be the ticket i'm going to order one now thanks again, dieselfan
Old Aug 11, 2006 | 07:19 PM
mcctho21's Avatar
That is the seal for sure. Chronic problem on our trucks.
Tom
Old Aug 12, 2006 | 12:23 AM
DodgeCowboy's Avatar
DTR's Cow Boss
another place to look is the steering gear were the pitman arm connects the sector saft has two seals and they go bad and its usally more safe to just replace the whole thing instead of R & Rin the seals. Thats were mine is leaking as of now.
Old Aug 12, 2006 | 07:01 PM
dieselfan's Avatar
how much for that? thanks dieselfan
Old Aug 12, 2006 | 09:34 PM
DTR's Cow Boss
it can vary depending on what you want to do. I belive that napa one is around 300ish but dont hold me to that its been a while since i checked on doin mine.
horton
Jul 25, 2011 11:30 AM
BG05TD
Apr 30, 2009 11:25 PM
armourbl
13
Jan 21, 2009 11:13 AM
Common
Nov 10, 2006 07:40 PM
