Help Finding Rear End Specs.?
Old Feb 6, 2009 | 10:08 PM
jadiehr's Avatar
Smile Help Finding Rear End Specs.?
Hi all, I have searched and found lots of info great info on this site and I think it is great. I have been searching for quite some time again tonight to find some specs. on the D70 rear end with no luck. This is my first posting and I was wondering if someone could tell me where I could find the page that was from Genos garage with all the torques, preloads, backlash adjustments, fluid capacities, etc. for my 2001. I checked on Genos site and was unable to find it. I do remember someone having the link on their forum for this though and the top of the page said Genos Garage on it. Thanks a bunch.
Jon.
Old Feb 6, 2009 | 10:31 PM
pind's Avatar
Oh boy
I just did the rebearing on my 01 rear end, and the only thing I found, was that I had to add a bunch of shim thickness to the pinion, to reduce the preload, as the stock shims made it way too tight.
Otherwise, if its a simple bearing job, as long as the bearings mic out the same, you shouldn't have any problems with setting it back to the same spec it was at when you took it apart. My side shims on the center section remained the same, as did the depth shims behind the cup for the rear pinion bearing. Contact pattern was perfect.
For the wheel bearings, I simply set them to . 004" endplay, and called it good. THis way they are not so loose as to wobble, and not so tight as to overheat.
Old Feb 7, 2009 | 01:15 AM
camelracer's Avatar
From the '01 FSM
Backlash: .005 - .008 in
Pinion depth: 5.375 in
Pinion preload: used bearings 10 - 20 in-lbs new bearings 20 - 45 in-lbs
Bearing cap bolts: 80 ft-lbs
Ring gear bolts: 130 ft-lbs
Pinion nut: 220 - 280 ft-lbs
Axle shaft bolts: 95 ft-lbs
Hub bearing nut: 120 - 140 ft-lbs
Old Feb 7, 2009 | 02:32 AM
98whitelightnin's Avatar
Is this what your looking for, there is quite abit of good info here.
http://dodgeram.org/support_pgs/diesel_ix.htm
Old Feb 7, 2009 | 10:47 AM
Barney's Avatar
Some more info here:
http://dodgeram.org/tech/specs/axle/267RBI_specs.html
Old Feb 14, 2009 | 10:10 PM
jadiehr's Avatar
Thumbs up
Hi, just wanted to thank you guys for all the info on the rear end specs.
thanks again, Jon.
CLS LLC
Aug 27, 2011 08:15 PM
Rick 12v CTD
Mar 23, 2009 05:43 PM
05CTDN8
Aug 23, 2008 11:53 PM
doorguy
Jun 8, 2007 06:19 AM
06RAMCTD
0
Dec 19, 2006 04:15 PM
