help diagnose a couple noises
Old Apr 3, 2010 | 05:39 PM
Beast2B's Avatar
I've been hearing a couple noises lately that I can't figure out. One is a clicking sound while decelerating (engine braking). It doesn't happen while coasting. I thought it was a U-joint going out, but they are fairly tight. Sounds like a bearing, but which one? Also, I occasionally hear a squeak at low speed. Sounds like the front right wheel. Maybe the front bearing assembly going out? I only have 91k miles, but I've been running 37s for 70k...
Any suggestions where to look and a good driveway check?
Old Apr 3, 2010 | 06:19 PM
SIXSLUG's Avatar
Maybe a brake pad? If you have a warped rotor maybe its causing the pad on that front wheel to move around.
Start from the outside and work your way in.
Old Apr 4, 2010 | 01:23 AM
dozer12216's Avatar
I had the exact same description for noise and found the trailer hitch loose and a Ujoint ready to fall out. No more squeaks and clangs.
Old Apr 4, 2010 | 01:33 AM
nickg's Avatar
A U-joint can feel tight, but can be totally trashed and even to the point of having ground up the needle bearings, a good indication of a failed U-joint is ANY rust colored dust near the caps or on the U-joint. If you see rust its a bet that its failed
Old Apr 6, 2010 | 09:42 AM
Beast2B's Avatar
thanks guys. i have gotten to the point that an empty hitch clanking around bugs the crap out of me, so i keep it out unless i'm towing. i think i'll do the u-joints for good measure... 4 of them in the rear with the double cardan joint...
looks like I'll be busy this Saturday morning!
Old Apr 6, 2010 | 09:44 AM
Beast2B's Avatar
once that's done, maybe the squeak will go away or fix itself! i'm REALLY hoping the front bearings aren't going.... doesn't sound like a fun project, but maybe that's the time for the manual hub with real bearings
Old Apr 6, 2010 | 08:25 PM
nickg's Avatar
yours must be different than mine, no double carden joint back there, typically its the rear U-joint that fails on the rear shaft...
so did you find a bad joint or rust??
NoSparkplugs
Oct 16, 2006 10:59 PM
GCSS
Aug 14, 2006 12:29 AM
mkubacak
Apr 3, 2005 01:32 PM
4x4dually
Mar 2, 2005 04:17 PM
HO Cummins
Nov 7, 2004 11:16 AM
