Help Diagnose
Old Dec 30, 2010 | 07:47 PM
A-Poc's Avatar
Help Diagnose
I've done some searching and couldn't come to terms on a proper diagnosis so I'll just describe my problem.
My father took his truck out the other morning(-10 F), drove a kilometer, left it running and came back after 10 minutes. In that time, he lost his steering and brakes. No visible leaks or puddles. The oil in the pump is light brown looking but is within specs on the dipstick. Everyone on here says put in synthetic but it seems like a light switch, one minute it's fine, the next it's not. What things should I actually test to narrow things down?
Mike
Old Dec 31, 2010 | 02:14 AM
Heimie's Avatar
From: Stony Plain, Alberta, Canada (just outside Edmonton)
Possibly a vaccum leak, as the vaccum pump supplements the power for the brakes and the steering.
Old Dec 31, 2010 | 07:47 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
I'm gonna hazard a guess and say the shaft between the vacuum pump and steering pump is broken in some way. with the engine running, remove the cap on the steering reservoir and see if the fluid is moving at all. If not, crack the pressure line on the back of the steering pump and see if fluid comes out. If not, the pump is not pumping for some reason. It's a pretty common problem. I would check out fixinrams.com and call Peter Gould. If something is broken down there, he would be the guy to call and get parts from.
NoSparkplugs
Oct 16, 2006 10:59 PM
GCSS
Aug 14, 2006 12:29 AM
mkubacak
Apr 3, 2005 01:32 PM
4x4dually
Mar 2, 2005 04:17 PM
HO Cummins
Nov 7, 2004 11:16 AM
