Help
Old May 6, 2003 | 07:25 AM
Deer716's Avatar
Help
I was driving my truck and lost my oil pressure. Dont know what to do. Any suggestions?<br><br> Thanks,<br> Ruben
Old May 6, 2003 | 07:54 AM
BarryG's Avatar
Re:Help
Seems that quite a few oil sending units have bit the dust. If you can check the pressure with another gauge to be safe would be best. There is a TSB out there to fix but all it does is turn your gauge into an idiot light(if you have pressure it reads 40psi if you don't it reads 0). If you can't check the pressure I would get a new oil sending unit and replace the original and see if that takes care of it. Dealer may replace the unit under warranty or they may do the tsb. I would check with them before they did it.
Old May 6, 2003 | 08:43 AM
Deer716's Avatar
Re:Help
Where is the sending unit located
Old May 6, 2003 | 07:53 PM
Ramflasher's Avatar
Re:Help
It is located just below the map sensor. (where you would plug in an EZ or boost fooler)
Old May 6, 2003 | 08:01 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Help
From www.dodgeram.org
#22 is the oil pressure sensor.
Old May 6, 2003 | 09:58 PM
brassbuldog's Avatar
Re:Help
I would have it checked by someone who is real reliable. I took my new Dodge van in for low oil pressure...they said it was a bad sending unit...don't worry about it...50 miles later...KNOCK KNOCK KNOCK...engine siezed up...they tried to blame it on me, but I had it in the shop the very day it croaked!!
Old May 7, 2003 | 07:51 AM
Deer716's Avatar
Re:Help
Thank you all for your help. I took it to the dealer today and they said they are pretty sure it is the sending unit. They said that the Federal Emission warranty would cover it.<br><br> Thanks again this site is awesome,<br> <br> Ruben
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
